Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Small amount of white sludge on oil stick
    VP Wagon V8 93
    Nov 2006
    Angry Small amount of white sludge on oil stick
    5.0 VP wagon 93
    Is it Head gasket? or is it the sludge removel that I put in two days ago still working through the oil?
    I have dumped oil and changed it after sludge removel.
    Car seems to be running ok.
    HELP !
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    I'd dump the oil again in about a week. Give it a bit of time to get into all the nooks and crannies of the engine, see if that helps. Small price to pay before you haul off to the mechanics.
    Life's Grouse in Frankston South!
    VP Wagon V8 93
    Nov 2006
    Thanks fazz1977, fingers crossed its just sludge working itself. Car seems to be running ok.
    1991 vn series 2 exec [URMONY] & 93 vp calais
    Apr 2006
    melb
    if its not that get a pressure test dont on the system that will tell you heads or not for about $90
    b4 you go do the heads and become a slice out of pocket
    ~~Nic~ says:
    yeah feel dick tho
    VP Wagon V8 93
    Nov 2006
    Fingers crossed its only sludge, bit weird that its white though, Normally that would be a head gasket I thought. But the car is running very well. Weird. Be good to do a pressure test anyway ! Thanks smokey_dj
    Apr 2006
    melb
    when i first discoverd about issues with the heads i had violent temp swings sitting still would just about peak in the red moving was fine but maybe sometimes a lil bit hotter than usual andway the white sludge im not sure about but milky oil is usually a sure sign but as you said couldnt hurt to do the pressure test just get someone you know as a mechanic to do it if they know how otherwise you will be told anything and charged anything regaurdless of gender ive never run a sludge removal agent so this is the best advice on what you have given to diagnose and no worries mate happy to help or try anyway :P
    ~~Nic~ says:
    yeah feel dick tho
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    While the cars running (cold) open the radiator cap and see if there are bubbles appearing in the neck of the radiator, if so this could indicate a gasket problem.
    VP Wagon V8 93
    Nov 2006
    Thanks Holden007 Ill go try that now ! Cheers, and cheers smokey_dj, i have a mechanic friend he is doing a compression test tomorrow morning.
    Apr 2006
    melb
    ahh thats the way and yeah good call on the bubbles test completly forgot about that
    i find it best to do it in the late arvo as themps are cooling as you get the most accurate resault with still the most sunlight without heat
    or vice versa in the morning
    ~~Nic~ says:
    yeah feel dick tho
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Quote Originally Posted by holden007 View Post
    Hey about a week ago i put a thread on here because there was heaps of moister in my exhaust and i thought i had a blown head gaskit. When i open the tank thing you put water in, it is frophy in there. I am hoping this doesnt mean i have a gastkit prob? when i opened it, it was pretty hot, is there meant to be bubbles in there when the cars has been running for awhile? The car wasnt cold when i opened the tank.
    Australia. Love it or leave it
    Apr 2006
    melb
    nah when its hot some bubles and a lil foam is ok in the top of the radiator its just on cold when you see the bubbles of doom gloom and pocket crunching boom but the exhaust moisture could be something that would point to that area of problem being heads or it might be something simple that i havent come across myself yet
    ~~Nic~ says:
    yeah feel dick tho
    Apr 2006
    canberra
    Yeah well my car isnt using any water so it must be alright.
    AE86, VE2 SSV M6 UTE
    May 2004
    Yeah, i get a small amount of foam/bubbles on my VN S1 inside the surge tank, nothing to worry about. What causes it is the breather pipe blowing water back into the tank causing bubbles to be formed....
    Subaru Liberty
    Dec 2003
    The bubble doesnt always mean you have a blown gasket, get pressure tested to be sure, remember head gasket is costly, so you want to make sure.
  15. #15
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    i would say its a blown head gasket white foam/or brown/yello foam usually means there is water in the oil, it could be some thing simple like a leaky intake manifold a blown head gasket or the worst a cracked head or block.
    dont just get a pressure test done get a chemical check done also, this will definatly tell you if you have a blown head gasket
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
  16. #16
    VP Wagon V8 93
    Nov 2006
    Done Compression test today.
    1: 130
    2: 120
    3: 130
    4: 120
    5: 138
    6: 140
    7: 118
    8: 130
    The tappets are a bit noisy so Iguess this explains number 7. From the resluts I guess my head gasket is ok? It must have been sludge removal on the oil stick. So all in all just worn valves? What do you think?
  17. #17
    VP Berlina V8 / Toyota Hiace
    Oct 2006
    SA - North
    Just abit of condensation in the oil.
    With the water from the exhaust its normal when the cars first been started.
  18. #18
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    i still reckon you need to go to a mechanic an get a chemical check done it will prove it for shore
    MY RIDES
    [SIGPIC][/SIGPIC]
  19. #19
    Oct 2006
    SA - North
  20. #20
    VP Wagon V8 93
    Nov 2006
    Can I do the chemical test myself? Whats invloved? I have never heard of this before.
  21. #21
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    if your not expierenced i dont think you can, also the chem check kit costs about $200
    MY RIDES
    [SIGPIC][/SIGPIC]
  22. #22
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    those compression figures seem a bit low. my V6 was 165 +/- 5psi on all 6 pots. i'd suggest doing the compression test again but this time put a couple of drops of oil down the spark plug holes first and see if that gives a better result. better yet, get a leakdown test done.
    Body by Holden, Soul by Brock
    the Legend will live forever
  23. #23
    VP Wagon V8 93
    Nov 2006
    The readings were done with the throttle closed, but even still, yes a little low. OK will try the other tests ! Thank you, Steve
  24. #24
    Oct 2006
    SA - North
  25. #25
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Quote Originally Posted by smokey_dj View Post
    Sh*t, a pressure test costs 90 bucks! Im in the wrong game. A pressure tester is just a glorified bicycle tyre pump.
    *Pump, pump, pump.*
    "No sir no leaks, thatll be 90 bucks please."
    I could retire by the end of the week!
    Im not a complete idiot, some parts are still on backorder!
  1. Oil sludge
    By 94SVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2006, 05:32 PM
  2. Maximum Amount Of Km's
    By andyman in forum General
    Last Post: 25-07-2006, 06:58 AM
  3. Does the air-con always draw the same amount of power when it's on???
    By vq~gangsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-12-2005, 08:37 PM
  4. Sludge Buildup
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2005, 10:26 PM
  5. Sludge Buildup
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2004, 10:30 AM
