Results 1 to 15 of 15
Thread: Central locking problem
    VP Wagon V8 93
    Nov 2006
    Exclamation Central locking problem
    Yo.
    $3500 in repairs and still going...........Had the car 2 weeks....But I love it...
    Next problem, My remote control does not work I changed the battery still nothing, were do I get a new one? Do I have to remove the chip from the old one for it to work? Or is there some trick I can do with a learning remote? I know with FORDS (sorry for swearing) that you can reset the remote with a combination of turning the ignition on and off.
    Thanks guys.
    PS HOLDEN RULZ
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i THINK u can get replacements from holden still.
    We got rep back, yaaay!
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Got one for my 91 VQ last week for $115 fully coded.you need to give them your code from inside your remote first.Just make sure that is the problem.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    mr minute sell a key/remote in one thingy for about 90 bucks i think.
    my remote was ghetto when i first got my ride, crappy range etc. i just got a learning remote from dick smith, but it requires a working remote to learn from
    VN Berlina
    Sep 2006
    Just Central locking question of my own.
    My mates VP Wagon has keyless entry...but the thing is the boot doesnt lock..has to be key locked..
    What could the problem be
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by Kid_Random View Post
    It probably isn't part of the central locking setup... Im not sure about wagons really, but I doubt the boot is included in the keyless entry.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by stmcomms View Post
    Yo.
    Thanks guys.
    PS HOLDEN RULZ
    a cheaper way to fix the central locking is to buy an aftermarket immobilizer with a remote for central locking. that way you'll have a new remote which will do exactly the same as the holden one, but you wont need to worry about getting it coded and crap. plus you'll also have an immobilizer, a must in any commodore.
    Vn
    Nov 2006
    Glen Iris, Vic
    i just installed a vr bcm so i got central locking, immoboliser, power windows when i get regulators, power mirrors and a few other things.
    1991_Vn2nV's Avatar
    Mar 2006
    Vn
    Nov 2006
    Glen Iris, Vic
    yeah but i've got alota free time atm an it filled in time. also i like the fact the i don't have an extra thing on the keyring as im just using a vr key.
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    My central locking is the one last problem that really s**ts me to tears. All the stuff is there. All the motors work when bridged to 12v, module works, no frigging voltage from the fuse box.
    Should I just run a new 12v into that fuse block from someplace else?
    Life's Grouse in Frankston South!
    mightymike's Avatar
    mightymike is offline Mighty_Mike
    VP Commodore 1992
    Nov 2006
    West Subs. Melb
    got the same problem, all of a sudden my cen. lockin wont work, changed the batt... no change
    Yo mudda is soooo fat.... dat when she jump for joyy..... she got stuck....seng you
    VP Wagon V8 93
    Nov 2006
    Ive fixed mine, I took the black button remote thing apart, I had two solder joints that had come loose, so i dabbed a bit of solder on each and now she works a treat ! In the photo you should be able to make out were I have put new solder on.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    The remotes are a bit finicky...dont know if holden still sell them but mongoose are the supplier.
    I got the same style remote out of a vp from the wreckers and had mongoose code it .They can probabably fix you old one anyway.
    What I have done before with results is sprayed a small amount inox on the blue variable capacitor in the remote and turned the adjusting screw in and out to the exact same position and it worked ok afterwards...but make sure you have a good contact on the battery first and of course have it in the right way.
    In a vp a wagon does have a lock solenoid in the rear door that is activated by the remote.
    Problem could be broken wire where it bends between the door and the body through the rubber grommet/cover.
    Well done budwizer!
    Who cares how hard or feasible it was to put a bcm into a earlier model especially after you've done it ...you learn something and it costs you next to nothing and you did it yourself ...hate those pricks who use the comment" you must have a lot of time on your hands"....its because they probably know bloody nothin and are jealous of people who do and thats their big comeback.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  15. #15
    fazz1977's Avatar
    Aug 2005
    My remote works fine, runs the immobiliser fine, no central, no voltage at fuse box.
  1. VT2 Central Locking Problem
    By Stretcher Bearer in forum Electrical Wiring / Questions
    Last Post: 04-03-2007, 11:19 PM
  2. VS central locking problem
    By the_negro_puppy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 11:19 PM
  3. (Another) VR Central Locking Problem
    By Riff88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2007, 12:51 AM
  4. Central Locking Problem
    By pegga in forum Electrical Wiring / Questions
    Last Post: 25-12-2005, 10:07 PM
