Results 1 to 19 of 19
Thread: AirCon change R12 to R134a
    VN Berlina V6
    Mar 2005
    Default AirCon change R12 to R134a
    Hi Everyone
    Just seeing what you think about this and have you had experiences with changing your car from R12 to R134a gas and costs ?
    I went and saw Red Devil Radiators and Air Conditioning and explained to them that I need are-gas but am on the r12.
    They said they would change out the accumulator and all the o-rings and hoses etc that need to be done plus test the system and gas and dye it for $340.
    Is this a good price - what are your exeperiences with this situation ?
    They said I would have to come back 2 weeks later to let the dye run around the system and see if there are leaks.
    AE86, VE2 SSV M6 UTE
    May 2004
    Seems a decent price if they are true to their word and actually change the orings, accumulator etc.
    The 2 weeks is usually standard as they can check if any leaks have occured (the dye will show up under uv light).
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Doesnt the dye show up under any light Atleast it did on mine. Very clear to see a few days later where the leak was.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Sounds like a pretty good price. Dad's a refrigeration mechanic, so I've never had to pay for aircon stuff, but considering that they have to change the refrigeration oil from mineral to synthetic as well which can be fiddly, $340 sounds good.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Quote Originally Posted by 1991_Vn2nV View Post
    In many cases it will since there is UV light naturally
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I changed my own & serviced it for $50 then paid $75 to fill it....
    I did all o rings & oiled all valves etc...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by HoZy View Post
    MaT
    So I'm guessing you just blew the refrigerant off to atmosphere?
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    It was empty at the time... An the little excess did blow off...
    MaT
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    MaT
    I'm all for doing as much as you can yourself, but releasing refrigerant to atmosphere is one of my pet peeves. There are enough old fridges/AC systems leaking the damn stuff already without dodgy backyarders blowing it off because they can't be stuffed doing it properly. But seeing as it was just about empty anyway, I wont yell at ya, hell a couple of years ago I ditched an entire system full by wrapping the condensor around a kangaroo.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    lol fair enough mate, well it was empty, had probably about a 1foot cloud puff come out, i wouldnt attempt doing it if it was still working/full..... HELL NO!!!!!!!
    Probably kill myself
    MaT
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    you would probably just put your self into a deep freeze. lol
    $340 is a great price (i do a/c at work) and we charge about 450-600 depending on the evaporator under the dash
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    Feb 2004
    340 $ plus to regas ???? you got to be kidding ?????
    for a vn commodore a receiver / drier is about $10-$15 max trade .
    regas about $120 ....
    or u could regas it with normal LPG !!!!! , done it and its colder than your normal car refridgerant gas,...
    and no more FLAMMABLE than normal car ref gas.
    mark k
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by krawczuk View Post
    mark k
    Not quite that simple buddy, from memory LPG has a higher energy density than most refrigerants, it IS more flammable and as you yourself have already noted has a very different pressure/enthalpy diagram to r134a. While the inside of your car is getting colder, the pressure and temperature in the condensor at the front of the vehicle are a fair bit higher than the designer ever intended. I honestly can't be arsed hunting down the numbers, but I will point you to this page, a particularly stupid fellow tried to prove that LPG isn't dangerous, didn't turn out so well for him. Footnote of the article also points out that using LPG in R134a systems is illegal, and for a damned good reason.
    http://www.vasa.org.au/pdf/memberlib...aine-cross.pdf
    LPG has really taken off as a refrigerant in europe, I've got no problem with the concept really, but running it in conventional systems isn't just a simple matter of dropping in the gas and away ya go. So if you don't know what you're doing, DONT ****ING DO IT!
    1991_Vn2nV's Avatar
    Mar 2006
    I only use NON flammable gas in my air conditioner system. It is available and you can easily request any re-gasser to use it in your system... It is much safer.
    Also LPG can be very dangerous, and its dangerous when the temperature is hot as it expands so much. LPG expands to 270 times its size when it goes from liquid form to gas form, and this is why you never fill gas cylinders more than 80%.
  15. #15
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Most refrigerants also do the massive expansion thing, it's kinda the point. Most common refrigerants are also flammable to some degree, not particularly easy to light but flammable none the less.
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by pandaman View Post
    Yeah but to the same degree as LPG?
  17. #17
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Yah LPG is a lot more volatile this is true, wouldn't want to contradict myself. The expansion thing I'm not too sure on the magnitude, but it's enough to give you some serious frostbite if you dump a full charge in a hurry.
  18. #18
    VN Berlina V6
    Mar 2005
    mark k
    The $340 included gassing.
  19. #19
    VN Berlina V6
    Mar 2005
    Quote Originally Posted by xcop5l View Post
    Whats the go with the evaporator under the dash ??
  1. How to change lights in Aircon and Demister buttons
    By buggzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 06:22 AM
  2. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  3. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  4. rb30... etc?? R134a??
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-08-2005, 09:12 PM
  5. Cant change Aircon settings VN
    By Slip in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2005, 08:19 PM
