Results 1 to 21 of 21
Thread: calais's first gtech run
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default calais's first gtech run
    hey, went out to a cruize and metup with vp_luke and hozy+tr3nt and dj_smokey were there too, luke lent me his gtech to play with... had 4 people in the car for starters first time... ran a 16.13 @ 84mph.... then a 16.33 later on (with wheel spin)
    after dropping everyone off i played with it some more, chaging to a tune foam made for me, i pulled off a 15.5 first run (down hill played funny buggers)
    then a 14.97, then a 15.24 and a 15.12 and a 15.72.... these were at the same peice of road, dead flat (highway)
    so 16.13 best time with 4 people in the car on stock tune
    and 14.97 best time on foams chip with just me in the car
    i am currently running shell V-Power 98RON aswell car has 1/2 a tank full aswell and a boot full of crap (subbie and amps)
    im pretty happy with this result, this confirms my calais is actually quicker than stock..
    here is the you tube video link just incase you dont believe me
    http://www.youtube.com/watch?v=dJeni_EYcOY
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    VP Executive R-spec
    Jan 2005
    Nah man somethings wrong with that. You didn't even get out of second gear and it's showing 103.2?mph, you should be pulling third for a couple of seconds shifting at 5200 to run a mid 15, mine used to be pulling about 145 on the speedo in third gear at the end of the run, that's what mine used to do and it used to get to 100 maybe 2 seconds quicker than that.
    The VP goes well over 150 at the end of the 1/4 on the speedo and the speed in the VP is behind GPS speed by about 5km/h at 150 ish
    VP Executive R-spec
    Jan 2005
    If you compare it to mine http://www.youtube.com/watch?v=BwiHG6CCq2U you can see that mine shifts out of first at about 5200 rpm at 4 seconds where's yours takes 5. So you're allready a second behind just in first gear.
    Or compare it to the VP http://www.youtube.com/watch?v=by-sj9jAUGk where it takes 3.5 seconds to get to the same speed and that can only run around a 14.7 on average also my 1/4 mile runs never vary more than .2 no matter how many times I run them
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ill run it again today foam but ill show u what happens if i run it down a hill next time your on msn... (massive valve bounce, even with rev limiter @ 6000)
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ill make some changes next run aswell no sub, no spare tyre more pressure in tyres, changing spark plugs aswell
    i ran a 15.3 today, diffrent strech of road... ive calibrated the gtech within 0.01 of a g hrmmmm how do u use the horsepower feature of it?
    VN Commodore
    Feb 2006
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    true but if they've got not much pressure they can drag, my tyres are rooted anywayi never get good take off's i think ill get em swapped next week
    Jun 2005
    to get the horsepower feature i think you need to enter the cars weight into it
    http://www.mustangworld.com/ourpics/hitech/gtech1.htm
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VN Commodore
    Feb 2006
    yeah that is right. ya do have to put the weight in. but i think ya have to convert it to pounds..
    VP Executive R-spec
    Jan 2005
    Yeah you have to set the gtech to .00 each time or at least .01 in either direction if you don't then it doesn't work. To get into power mode you move the switch across to P it's the furthest setting across, then you tilt the gtech untill you get to how many pounds the car weighs with you in it. Then put it back on the mounts, then give it some stick in 2nd gear. This will give you a power reading but you will be 25 rwhp down on a dyno figure as the gtech also counts air resistance which is about 25rwhp at 100 km/h on a commodore.
    My VN used to read 133rwhp(158rwhp/117rwkw without wind) and the VP does 167ish rwhp(192rwhp/143rwkw without wind) I was only guestimating the weight of both cars at 3350 pounds (but should be within 50 pounds for those cars). Of course the VP makes alot more torque down low and gets out of 1st gear alot quicker so it ends up faster even though it doesn't have much more top end power.
    I only used it to make comparasions from one spark advance to another so it didn't really matter if it was accurate to a dyno or not for me.
    PS you will go much faster shifting at 5000-5200 rpm than you will holding the gears
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    hehe cheers, ill have to try that, auto bahn have a %40+ off sale... they'res a gtech and im eyeing it off... also a BOV... i could get the BOV for $50
    lol closing down sales are cool
    Jun 2005
    which autobarn? and what gtech do they have? i wanna know how your calais manages a faster time than greenfoams lexcen
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ok.. something popped into my head that luke said last night... vibrations throw the readings off, my car needs 2 new engine mounts... vibrates a fair bit.. could be playing funny buggers with my times...
    ive run a few consistants 15.7s and 16s so id take a stab and say thats more accurate.. i got the gtech to tell me my car had 292hp @ wheels.. lol
    oh well ill have to take it for a real quarter
  15. #15
    1991_Vn2nV's Avatar
    Mar 2006
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    engine mounts are just worn, i havnt had a look at em yet but was told they're fine just will be a bit bumpy and i should get em done
    i will be replacing them but the engine is going to come out for that to happen as i need to replace the flex plate aswell (have the flex plate)
  17. #17
    VP Executive R-spec
    Jan 2005
    Vibrations are ok, What can throw them out a bit is when you change gears really hard in manual but still it wont change it much. How much power did it have when its set to 3350 pounds?. Also they aren't accurate when they are hot, like been sitting in the hot car. Apart from that if you set them flat it should run the same time every single time
  18. #18
    1991_Vn2nV's Avatar
    Mar 2006
    Ah ok, I thought you meant they were actually broken
    Make sure ya get to the track before the turbo man. Be very interesting to see before and after results.
  19. #19
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    lol need a new radiator or a massive flush mines blocked as....
    im not having any luck with the gtech foam might go down to the track one weekend cant afford it atm, getting the turbo soon
  20. #20
    kwik6's Avatar
    kwik6 is offline stroke it baby
    vz ss cobalt blue/ hk prem chev
    Feb 2006
    rowville, melbourne
    whos doing the turbo set up? you interested in organising a heathcote day with some of us vn-vp owners?
  21. #21
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    Quote Originally Posted by PaRaDoX616 View Post
    bugger...
    no cops on that flat stretch of highway???? best be careful hittin those sorts of speeds on public road
    Something I've Been Getting Into Lately....
    Get Paid To Surf The Internet!
    Program About To Be Released So I Jumped Aboard...
    http://www.agloco.com/r/BBDB3431
  1. anyone know any good commodore wreckers for calais's
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2009, 12:48 AM
  2. Gtech
    By nathans1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2006, 04:01 AM
  3. Does VN 91 Calais's have an O2 sensor
    By Benji in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2006, 09:04 PM
  4. What wreckers in the melbourne (SE suburbs) have calais's?
    Last Post: 06-02-2006, 01:51 PM
  5. Gtech pro
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 02:28 PM
