Results 1 to 6 of 6
Thread: level 2 cluster
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default level 2 cluster
    ok people, had my cluster in my car and now the rpm guage doesnt work all the tym, it sometimes works fully, sometimes only goes upto a certain rpm and sometimes not at all..... is there a way to fix this? or dus it look like the cluster is going 2 holden heaven? anyways thanks in advance
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    I'd be checking the soldering on the printed board as it may have a small crack or something in it
    If ignorance is bliss why aren't there more happy people around ?
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Mine used to do the same. I did what it says in the thread below and it's fine now. It's pretty easy to do if you're ok using a soldering iron and taking the cluster apart, but PM me if you get stuck! I also posted up some pics when I did it. If you can find that thread it may help too.
    Solution to Sticky fuel/temp guages
    Edit:Just found it
    Tacho / speedo sticking
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    thanks for the help . ill give that a shot when i get a smaller solder(all ive got is the big bastard haha) so when i get a smaller one and some smaller wire ill give it a go.. thanks heaps appreciate it
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    I picked up a fine tip soldering iron from supercheap for about $15. It takes a while to heat up properly but other than that it's fine.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by Shortstuff View Post
    kool thanks m8... ill go buy 1 in a couple weeks maybe, when im not using the car... the L1 cluster shits me hahaha
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. replacing level 2 cluster with level 3
    By Matt_vp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2010, 09:30 PM
  3. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  4. Replacing level 2 cluster with level 3.
    By madmick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 11:18 PM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
