Hi, I am doing a compresion test with a friend comparing engines, I dont know what compression his car should be, HIs engine is a Windsor with a E303 Cam, Mor importantly I have a Factory VP 308, and I was wondering if anyone would know what my compression should be? Also will the cam alter the compression from the normal factory model in the Windsor?![]()
the cam may give you a different reading
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
i can't see how the came will give you a different reading.. as full compression is read when the valves are shut.. right????
i agree with hillerus. if they all read low i reckon that would be better off that them all reading 130 except 1 or two reading at 110 or something..
