just wondering how to put 17" on a vn. it looks like itll fit with about 40 profile but not sure. and what do you have to do to get 18s under there, change the strut?? the back looks fine unless you go over 235s and the back is what i thought would be the problem. anyone out there done it??
13.3 1/4 exhaust only untuned!
i can tell you my self they fit mate...
im using 235s/45z/R17
you have to roll the rear guads to fit them in tho (if its lowered) but its a good idea to do it anyway
you can fit even 20s in there(PIMPVQ)
but 17/18/19s should go straight on no hassles just rolled rear guards
thaks. just wondering coz my mate jsut got 16" 55/225 and his is on low king springs i think n he gets strut rubbing and gaurd rubbing when he turns.
nah man thats not the strut rubbing
im currently sitting on ulra rears and super fronts and i have no issues, you may want to fix up the camber on the front..
the inner guards might rub, i get it when im turning and hit a bump too hard just a bried bump but yeah nothing serious...
front camber is ajustable?? yeha it is the strut the gap between the rubber and the strut (lower end of the spring holder dont no technical name) is about 5mm and sometimes it is rubbing.
sounds like some thing is wrong with his front end
im sitting on super lows all round and 225/60/15 tyres and no rubbing at all
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
on 17's, 45 profiles look better than 40s. the smaller tyres look abit weedy, and the bigger ones fill out the guards more
I have ultralows in the front, superlows in the rear.
My car has 19" rims wearing 245/35 tyres and that fits fine. Although there is only 5mm clearance to the spring seat, but thats because the tyre profile is larger.
I have an adjustable rear panhard rod and rolled guards as well...
Last edited by 1991_Vn2nV; 15-11-2006 at 11:36 AM. Reason: Forgot to say I had to roll the guards...
i've got 17" clubsport rims(235/45/17's) on the VN and they rub a little on the back but when i had the 17" VTSS rims they didn't rub at all so ther must be a slight difference in the offset. you shouldn't ahve an problems though
Body by Holden, Soul by Brock
the Legend will live forever
