Results 1 to 6 of 6
Thread: respraying VP rubber window trim.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default respraying VP rubber window trim.
    the rubber stripping between the windable window and the other window on the back door of my VP looks a little perrished in parts. not horribly, but some of the shine and finish is coming off parts of it.
    Attachment 30012
    i bought some K+H vinal plastic paint, but just thought i'd check if this is appropriate for this area. (ie masking the window/rest of the car and then spraying coats on until it's gloss again)
    the rest of the window surrounds are fine, but this bit's always looked a bit ghetto.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    aslong as the paint is flexable then i dont see why its not a good idea...
    worse that can happen is it can flake off??? its black right???
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by PaRaDoX616 View Post
    yeah, just didn't want to end up with a sticky mess of undried paint or whatever.
    weather's kinda weak right now, i'll give it a shot on the next clear day
    xlr8_87's Avatar
    xlr8_87 is offline No longer a commy driver
    '96 Prado 4x4
    Mar 2006
    Melb, VIC
    i have the same problem, let us know how it goes dude
    <<<Rob>>>
    Ecotec VP, 135rwkw, 427nm
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah man, i did it today, washed my car, getting the areas extra clean, then masked up the car with old bedding and newspaper, and used K+H vinal plastic paint.
    it came up pretty well, the stuff is pretty high gloss, but it's better than the ghetto look it was sporting beforehand.
    the first few coats just seem to soak into the rubber, then after a couple more it starts to look awesome.
    i guess it depends on how shiny you want it, do more or less coats.
    K+H and a few other brands seem to do a few paints for trim, but this one seemed better suited.
    i guess summer will be the decider.
    VP Executive R-spec
    Jan 2005
    Easy way to spy a VP is you don't know how they look is just look for a car with the rear window surrounds still silver and the rest black:P they were all shiny silver once but it's alllllllll gone now
  1. vs window seal rubber
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 07:30 AM
  2. Rear Window Rubber Seal Vt.
    By fabz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 07:31 PM
  3. Rear Window Rubber Seal Problem
    By junka in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-02-2007, 02:06 PM
  4. Door Trim Rubber
    By Bax in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-04-2006, 05:59 PM
  5. Front Window Rubber Seal
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 02:42 PM
