Results 1 to 20 of 20
Thread: blown headgasket, anything i should do while im down there?
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default blown headgasket, anything i should do while im down there?
    hey guys,
    i blew my headgasket probbly a while ago just been too lazy to change it as its not majourly bad.. just been leaking oil into the radiator, and its getting worse now... cooking the coolant etc
    anyway.. ive got a set of spare heads in my garage off a s1 vn that had done 160,000km (mines done 280,000km)
    so i figure i mayaswell slap them on as mine have taken a pounding
    but before i do im going to port and polish them (not majourly just enough to flow better)
    is there anything else i should do when im down that far into the engine???
    i mean like maintence things.. that dont cost lots
    also should i replace the valvestem seals while i have the heads off the car and how much do they cost???
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Dont lower the comp while its N/A will run like a slug. While apart what you do, depends on your coin. If it were me I would get some hardened pushrods, roller rockers, springs that can take a high seat pressure, collets, etc.
    No coin, a quick going over with the dremel and check the valves, etc for wear.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah coin is tight... pushrods/rockers can be done while the heads are still on the car and very easily... i ment while the heads are off, i wanna do valve springs but my budget is tight...
    last time i checked a set of new valve springs was like $220??? am i correct or can you get them for cheaper if so where from???
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Also while you have the heads off crank the engine over by hand and check the condition of the pistons and what you can see of the rings.
    AirStrike
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by PaRaDoX616 View Post
    $220!!! Try pricing Isky ones to suit a 5.0lt
    AirStrike
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    lol... i think thats why they released the 5 banger, for people who are too good for a 4 banger and too cheap for a v6 :P
    anyway cheers ill do that
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    im getting crane valve springs for $99 for a 5ltr dont no how much for v6
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah been talking to like he got his crow springs for like $60 so ill do them when i do the heads...
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    if you want proformance parts theres a good place in geelong for them, johnny dyno's engines (52785753)
    gets all sorts of proformance stuff
    MY RIDES
    [SIGPIC][/SIGPIC]
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    thanks mate, what else can i do for performance to my heads while they're out
    also heres some pics (i got the heads outta the garage)
    the carbon just has slight scratches in it the metal isnt penetrated
    the valves are good and not cracked aswell
    Attached Thumbnails Attached Thumbnails blown headgasket, anything i should do while im down there?-p11-14-06_19.13.jpg   blown headgasket, anything i should do while im down there?-p11-14-06_19.14.jpg   blown headgasket, anything i should do while im down there?-p11-14-06_19.14-1-.jpg   blown headgasket, anything i should do while im down there?-p11-14-06_19.15.jpg   blown headgasket, anything i should do while im down there?-p11-14-06_19.15-1-.jpg   blown headgasket, anything i should do while im down there?-p11-14-06_19.15-2-.jpg
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    get em re surfaced and crack tested. just in case
    MY RIDES
    [SIGPIC][/SIGPIC]
    VP Executive R-spec
    Jan 2005
    Luke got some springs for his V6 that spin 6000rpm ++ for 60 bucks I believe, they are pretty cheap unless you are going for some that can deal with a huge cam and 8000 revs
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    foam, what actaull determines what the engine can handel in terms of RPM, i know cam shaft does but what else?? valve springs
    luke got crow valve springs, would they give better feeling when i hit the redline insted of bascially shaking the car to peices???
  15. #15
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    the first thing you want to do is stop valve bounce
    MY RIDES
    [SIGPIC][/SIGPIC]
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    it only valve bounces on a stock tune, its a auto and sometimes if its going on a slight decline under full throttle it will valve bounce and sometimes on a flat/uphill... revlimiter set to 6000 dosnt do it and dosnt hold between 5500-600 0 for very long just uses it for heatroom to shift...
    read through that post... hes putting money into some things that dont need to be done
    i need to drain my oil before opening it up obviously, what should i replace it with??? and ill do oil filter while im at it
  17. #17
    VP Executive R-spec
    Jan 2005
    The cam doesn't change what it can handle it just changes at what time the valves open and close and how long for. The timing of the valves in relation to the tuning pulses in the exhaust and inlet determin where the car will make peak power. The inlet and exhaust having more influence than the cam but the cam ties it all together.
    But the gforces on the rods and pistons and rings and crank are massive at high rpm and those parts are what limit you from doing huge revs without breaking. You can also destroy all the parts in the valve train pretty fast if the springs aren't holding the lifters on the cam. Other things in the engines design make it easier for a engine to safely make more revs, lighter parts (less gforces) less stroke (less gforces), Overhead cam (less parts and lighter), rotary (no valves "really light", no piston, no rods, no real crank=good)
  18. #18
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    thanks foam!
    does anyone know prices on valve stem seals???
    and is there anything else i should do???
  19. #19
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    most vrs kits come with them, but im not sure about the vn v6 ones
    MY RIDES
    [SIGPIC][/SIGPIC]
  20. #20
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    too late... i think my engine is going pop....got half way to tafe and it stalled 40 times trying to get it back home
  1. Blown Headgasket?
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 05:35 PM
  2. Blown headgasket - what else can be done?
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2007, 03:31 PM
  3. blown headgasket...
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-03-2007, 11:10 AM
  4. Blowen HeadGasket I think
    By darktele in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2005, 01:50 PM
  5. how do you fix blown headgasket? gemini
    By bass_master in forum General
    Last Post: 10-09-2005, 08:22 PM
