Page 1 of 4 1234 LastLast
Results 1 to 25 of 81
Thread: VP Tail light idea!!!
    VE II SV6 Sportwagon
    Sep 2005
    Arrow VP Tail light idea!!!
    g'dai guys,
    ive got a 92 VP calais, and like majority of VN VP owners have probs with faded or rear tail lights not working, ive been thinking of solutions to try and fix this, unfortunatly VP calais tail lights are unavailable brand new,
    though i've thought of an idea to get good brake lights plus help give it a modern update, as all the new cars these days have LED tail lights, iv thought about wiring up sets of LEDs and placing them in the tail lights, wondering if any1 has done this to and older model commo. or no if its possible and/or easy??
    cheers
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    http://cgi.ebay.com.au/1157-BAY15D-2...QQcmdZViewItem
    a pair (2x) of 1157 BAY15D (double contact) 24 LED replacement bulbs for tail/brake lights. Available in WHITE or RED
    These LED's are a must for any vehicle. Fits vehicles which use 12V - simply remove the old filament bulb and plug with these LED's and compare!!
    Each bulb consist of 2 layers - 18 on the top, 6 on the bottom.
    Replaces:
    Tail/Brake light - when the brakes are applied the LEDs get brighter.
    Benefits of LED over Filament bulbs:
    Colour never fades
    Greater Life span
    Low power consumption
    Shock & Vibration Resistant
    Low Heat Generation
    Quicker On/Off response times
    Wide angle
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    Sep 2005
    have u bought these Kowan?? if so any good, or any pics would b great!!
    although its not really wat I had in mind as the reason my tail lights do not always work is because the terminal that makes contact with the bulb doesnt always make correct contact, hence y with the LEDs i would connect them str8 in2 the wiring, rather than sliding in2 the terminal
    kowan's Avatar
    Sep 2005
    Far North QLD
    that would make it hard to replace the bulbs.
    No I havnt bought any led bulbs yet....click on that URL and see the pictures
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Nah they look shit.
    Theres a thread on here about them. They're too centered. It just shows a blob of light rather than filling the actual area of the tail light like normal globes. Its because the light is aimed straight out...
    An actual LED setup would be MUCH better.
    Sep 2005
    ye thanks for that Vn2nV, confirmed what i was thinking,
    any idea how hard the LED set up would b 2 make, ie: with the 2 stage light, for tail lights then braking light on top, resistors and so forth, as mentioned id like 2 go str8 in2 the wiring, rather than using the old buggered globe socket
    1991_Vn2nV's Avatar
    Mar 2006
    Oh and I forgot to mention, Dick Smith sell those LED globes as well.
    I dont really know how the 2 stage light thing would work...
    But if you take the tail light apart, just using the black plastic and somehow layer them like this.... Is this what you mean?
    O O O O O O O O O O O O O O O O O O O
    W W W W W O O O O O O O O O O O O O
    ......................O O O O O O O O O O O O O
    W being the Reverse Light and the blank spaces being the reflector... I reckon it would look good! But maybe run some more LED' around the outside where the rest of the red is, hooked up to the tail lights.
    Sep 2005
    lol ye nice diagram, ill take it apart nxt week wen iv got sum time,
    mayb i should just buy sum of the 2 stage globes, and c if i can take them appart myself and use the resistors and watever else it has in it to make it 2-stage, and then spread the LEDs accross the inside of the plastic.
    JSTPOZN's Avatar
    JSTPOZN is offline S.A. The Defect State
    Air Bagged VR Calais, VLCT RB20, VLCT EFI V8 Turbo
    Dec 2005
    SA, North
    i tried it. the leds dont light up brighter at night when parkers are on.
    If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
    Go Here --->
    http://forums.justcommodores.com.au/...tml#post683835
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by T-ROY View Post
    Thats an idea.... And I thought my diagram was killer
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    the problem with the new ve LED lights is theyve been blowing up.. weve had to recall 5 hsvs to replace the right hand rear tail lamp
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    Sep 2005
    just thought id put a bit of an update here as to what im doin,
    ive looked around at the 2-stage led globes n theyll cost bout 20-30 buks for tha 2, and i spoke 2 the guys at jaycar and he ran me through all that would b needed to make these lights (these will look better as they will b on a board or circuit, so they will extend accros the whole light lense)
    and it works out cheaper, mayb tha same, depends wat strenght LEDs u go.
    but he said the 2-stage is easy done, and i should b doin measurments of tha tailights so i can go buy all tha stuff and get started on them. : )
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    theres a guy on another forum has done this, looks brilliant, he used holed mesh aluminium to put the leds in, can curve it properly and gives even coverage.
    Attached Thumbnails Attached Thumbnails VP Tail light idea!!!-100_0899111.jpg   VP Tail light idea!!!-100_0903111.jpg
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    loooks so ugly imo..
    wouldnt it be nice to have transperant len's on your headlights...hmm..
    Go Here --->
  15. #15
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Quote Originally Posted by hakhawk View Post
    They look sh1t hot
    Illegitimi Non Carborundum
  16. #16
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    i want them bad :O.... hahaha they should make some like that
  17. #17
    hakhawk's Avatar
    Jan 2005
  18. #18
    Sep 2005
    hakhawk, that bloke isnt on just commodores at all??
    cause thats wat i was looking to do, although i was goin to use tha circuit board tha guy at jaycar had, though id forgot about tha curve, so that may be better.
    i would love it if u had that guys contact details so i can ask afew questions about it,
    cause i really want 2 design these and make them a really good job, so-as im not driving around like a tosser with faded/not working vn/vp taillights anymore !!!!!!!!!!
    also anychance u no whether his used red or white LEDs in tha red sections, as iv thought about buyin red, but not sure if itll give tha right look, with red shinning through tha red plastic....?
  19. #19
    hakhawk's Avatar
    Jan 2005
    he hasnt got his email address on the site, but his username is exchaser308, and his cardomain page is http://www.cardomain.com/ride/609818 if that helps, hes using all white leds for it.
  20. #20
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    lol
    why bother about the led's... waste of money inmy opinion.
    just get exec lights and get the stripes plastic chromed.
  21. #21
    hakhawk's Avatar
    Jan 2005
    some people like to be different, have different tastes, if i had a sedan, id go the led ones in an instant.
  22. #22
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    this is something diffrent...
    unique hahaha
    Go Here --->
  23. #23
    1991_Vn2nV's Avatar
    Mar 2006
  24. #24
    Sep 2005
    Veeps calais. if i do the LEDs i will be buying a new set of lights and puttin tha chrome on them, but because they will b brand new lights, i dont want gay old globes in them, i want to modernise them abit. plus my looms that the globes sit in are the buggered bit that is causing tha lights to not work sometimes, so this way ill jus go str8 into tha wiring.
    and any chance you no of a place that does plastic chroming? anyone? (im in melbourne) otherwise i was jus gona get a signage guy 2 make chrome strips n stik em on, but id rather chrome.
    and cheers to hakhawk for tha help!!
  25. #25
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    Just go to a electroplator they wll have the tape to go on...
    they do it for vl calais lights in chrome too...
    dont worry about veeps calais he has faded calais lights himself...
    Go Here --->
  1. VQ tail light Q
    By VL-187 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2007, 08:02 PM
  2. Tail light warning light
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2006, 06:27 PM
  3. Tail light Warning light
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 08:15 AM
  4. Tail light
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2005, 12:55 PM
  5. Tail Light
    By FullySik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2004, 05:59 PM
