Results 1 to 11 of 11
Thread: are series 1 and 2 v6 transmissions the same..
    VN Commodore
    Feb 2006
    Default are series 1 and 2 v6 transmissions the same..
    as the title says.. are they the same.. i am selling my series 2 motor and the bloke has a series 1. he said his auto is fine so he doesn't need my auto. so do they bolt up. and input will be good..
    thanks..
    VP WAGON V6
    Mar 2006
    no they do not
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    i have a auto off a series 1 bolted 2 my series 2 motor and it all bolted up and seems alright
    Matt
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    I have a S1 auto on my S2 motor, no difference
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    I think the manuals won't as Series 1 had 6 bolts and Series 2 8 bolts or the other way round
    If ignorance is bliss why aren't there more happy people around ?
    VN Commodore
    Feb 2006
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yeh, the autos should be the same, its only the flexplates on the motor itself that changed and that was only the amount of bolts.
    Oct 2006
    Ive just helped put a s2 motor out of a VR in a s1 VN. Found that lower part of bellhousing was different. Easy to swap the s1 backplate though.
    VP WAGON V6
    Mar 2006
    yeah im pretty sure that there is also a diffrence in the shift. There is 2 types of box and unless you do something inside it you wont have overdrive if you swap between the models (no this is not the electronic box) my mate who owns a workshop has made this mistake before and erged me to get the correct box when i had to change mine.
    - OWA650 -
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by commy92 View Post
    i have all 4 gears 1st 2nd and both d's
    VN Commodore
    Feb 2006
    yeah that doesn't make any sense at all. you are just bolting a motor on teh front of it to drive it.
    but stanger things have happened
  1. vr series 2 transmissions
    By vrantman in forum V6 Development And Modification
    Last Post: 17-11-2010, 10:02 PM
  2. transmissions
    By VR 3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 11:00 AM
  3. Transmissions
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2005, 04:48 PM
  4. Transmissions
    By VPower in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 04:57 PM
