Results 1 to 11 of 11
Thread: differences between various models
    VP ute
    Mar 2006
    Default differences between various models
    What diffences exist between series 1 VP, and the series 2 VP with respect to the motor only? Also the differences in the motor between VR and VP 2?
    I know the VR has the sequential injection but what other difs are there?
    Are the Cams different between VN series 2, VP series 1 and series 2?
    Are there differences in compression between VN 2 , VR and VP series 2 motors?
    Is it just the ECU tuning between all these that gives the power diffences (aside of the VR with better injection).
    Will a series 2 VN motor run fine off a VP II computer?
    Lots of questions but hope someone knows
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    ok.....
    the ecu is the same but the tunes are not... the VR has a computer controlled transmission and more fuel maps (lean cruize aswell)
    as far as i know the only majour cam change was from vn S1-->S2 due to old grandpa's spinning them up at the lights lol
    yes the vn s2 motor will run off a VP s2 computer.. just might want to run a VN s2 tune in it tho (you can even run a VR tune made for a VN/VP)
    as far as im concerned the VN/VP/VR motor is pretty much the same engine, just small changes to make the engine better (rear main seal etc)
    vn s1- 125kw
    vn s2- 127kw
    vp --- 127kw
    vr --- 132kw
    when the got to the ecotec they matched the exhust ports, reduced the length of the conrods, removed dead weight, and raised compression a bit? i think just to make it perform better N/A
    VP Executive R-spec
    Jan 2005
    Nothing
    The VR has semi roller rockers, and higher compression
    The VR has batch injection the same as the VN-VP but it runs a more complex and better program on the computer
    Shouldn't be, it's the same engine
    The VN-VP engine are the same the VR has more
    Mostly yes but the exhausts also changed and the inlet manifold slightly
    Yes
    The VR engine is the best of the lot, It makes the most power and has the most mild tune
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Could you run the injection program off the VR on the VNS2/VP engines? And would there be any advantage?
    VP Executive R-spec
    Jan 2005
    Everyone kool runs the VR program man, where have you been living:P. I reckon you posted 4000 times and read 5 posts, lol
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    i run a vr manual tune on my vn motor, roughly the same power, but the vr lean cruise rocks, i can do a 100k trip to melb and only use 1/8 tank of fuel.
    remembering looking at my motors in the shed, the vr has a cam sensor on the timing cover, but the vp doesnt. im not sure if the vr manual runs one though.
    other than whats been said, i cant think of any other differences.
    the rockers on the vr, the stud has bearings for roller action, but the actual rocker itself from what i can see is the same as vp, vn, solid tip.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by greenfoam View Post
    Nah man, I read my own posts too So I've read around 4,500 posts
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    lol, my car runs a VR tune very badly but good at the same time... idles like the engine mounts are bungie leads might be the mounts tho still idles too high, might be better when the engines back in 1 peice
    VP Berlina V8 / Toyota Hiace
    Oct 2006
    SA - North
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by V8 Berlina View Post
    Get a V8 and be done with it
    its not like v8 blocks grow on tree's :P
    i mean i planted some heads in the garden trying to grow some V6's but they just wont grow.. only rust
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by PaRaDoX616 View Post
    ok.....
    vn s1- 125kw
    vn s2- 127kw
    vp --- 127kw
    vr --- 132kw
    VR is 130kw
  1. What are the differences VN SS and VP SS?
    By willygrice in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 06:26 PM
  2. V8 differences
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-09-2007, 08:45 PM
  3. VX differences
    By zohpm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2007, 10:35 AM
  4. differences in vn v6 and v8
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2007, 02:28 PM
  5. vs/vr differences
    By sarj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2005, 12:32 AM
