Results 1 to 11 of 11
Thread: Fuel tank ponderances
    1993 Series II VP Calais
    Sep 2006
    Question Fuel tank ponderances
    G'day. I drive a Series II VP Calais, with the 63 litre tank. I've been noticing that when I'm running a little low on fuel (usually around 8 litres or less), my engine starts hesitating on acceleration, especially when I pull hard, or take off up hill.
    Does this happen to everyone (ie, is it something that this tank and fuel pump just does), or is there something wrong somewhere? If it is a normal problem, has anyone tried to correct it?
    Cheers guys.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    from what i understand the fuel pump starts pumpin air rated fuel and you dont get as much fuel into the cylinder
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Fuel injected cars should never be run below 1/4 of a tank because the pump uses fuel to cool itself and should be submerged at all times. There is no problem with it you just shouldnt run it with such a small amount of fuel in it.
    Im not a complete idiot, some parts are still on backorder!
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Has your tank got any dents in it at all? My tank runs out before red it's got a nasty dint.
    My mates old VR berlina ran out with 30km left it also had a large dint in the bottom, Could be that?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    Quote Originally Posted by Slick_Get_Away View Post
    Mine has some big dents in it, and ive run mine on the red line and didnt run out(on the first drive to the servo after getting it registered). If the dent is directly under the float it will be a problem but if its not it will displace the same amount of fuel to push the float upward, the fuel guage will go down quicker but should still read nil when there is nil fuel.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Only works for people who have normal tanks but, And still noone on JC can work out what size tank i have, It's not 63 it's not 80. Runs miles over the full when filled and cuts off before red. It's larger then the stock executives but smaller then the V8's.
    VP Executive R-spec
    Jan 2005
    There's more than 2 tank sizes man! I was reading about this not long ago with all the option code stuff
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I don't have any problems running mine right down to an indicated empty, but I think my guage mis-reads as I can only ever get about 55 litres in when I fill up.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    So what is in the middle? 71 do you think??
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    68 litre in wagons
    If ignorance is bliss why aren't there more happy people around ?
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I wonder if i got a wagon tank?
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:29 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  3. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
  4. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 09:01 AM
