i have just recived my batronix usb chip programmer i have the memcal apart and sitting inthe programmer , but the software that comes with the batronix programer wants to know the chip source or type what ever i have the bin i want to flash but i need to know the chip source first
my chip says
DELCO
BAAM
0265
980
1606 9300
bldp9227 2068
anyone please
it will be some kind of 27c128 try reading it as one of the generic ones
they used several different manufacturers
you cant "flash" an eprom it needs to be erased with a UV light
Rob
how do i erase it with a uv light i have a tube light in the garage
do a search & read greenfoams thread on programming, this outlines all the equipment needed to do it.
its a specific UV wavelength needed to erase the eprom before programming
Rob
can someone confirm the chipsource i cant see what a generaic one is there are a few with am in from of that set of numbers u gave me
try setting the programmer to AMD 27C128 & read it off
it should checksum as 0012FF1B if you have read it properly
Rob
what happens when you use the auto identify button?
that button is greyed out when i plug in the programmer
what model programmer did you get?
batronix usb programmer
i think you should contact them for support, it looks like the software automatically updates the firmware in the programmer & is striking an error
Rob
im not sure there is a button at the top that is or firmware updates
i hope i didnt buy this thing and it dont work
is there any other software that will work with this
not sure, have you read the manual or an FAQ on the website for hints on the error message?
nothing usefull there regarding my error
yeah i had a look, i think you will have to email them regarding it, send them the picture too
i wonder if there is a older version i can use or a 3rd party software that will work this this programer
hey can i get a different chip and use it? can i get a vr or vs chip and program that? i hear that there is some extra features using a vs chip? if true what kind of features
if youre having problems best start with something simple until you get used to it. stick with the VN programs
i was thinking of getting a diff chip that works lol...
doctor bob greenfoam any of you guys that have a baam definition xdf or ecu
i think its BAAM0265 $FB please anyone i just need it to make sure my new burner is reading correctly
have a look at the bin in a hex editor, theres just a bit of an offset when compared to the $5D
