Hey all i have a VN Calais S2 and i have been doing some long distance driving lately and i have just noticed when ever i put my foot down to overtake it will jump back a gear from OD (4th) to 3rd gear so i can speed up and get passed then when i slow down to comfy speed again it won't change gears and i'll be doing 110 and it will be reving at 2500 - 2800 rpm as uppose to 1800 - 2000 rpm in Overdrive, however i would stop the car turn off the motor and pump the pedal a few times and then start back up and slowly drive back off working its self bacvk through the gears until i reach 110 and then its in OverDrive (4th) again, Its as if something is sticky on the cables, but where ?
Thanks, any help appreciated.
I was having an argument with my missus and she said "You don't even know what love is!"
"Sure i do, its that white stuff."
Check it out!
It could be the throttle spring. open and close the throttle and see if it returns quickly or slow. Also you have the cruise control on when you do the kickdown?
Another way is to disconect the cruise control module cable and see if the throttle stick when you drive.
if it is the "pumping of throttle" that fixes it then you should be able to do it while car is on probably a dud gearbox check oil maybe.
13.3 1/4 exhaust only untuned!
