Results 1 to 3 of 3
Thread: Eprom/eeprom Erasing & Size's ?
    Nov 2006
    Default Eprom/eeprom Erasing & Size's ?
    can a normal UV light thats on the cieling of my garage work to erase my eprom?
    also can i just get a eeprom instead of a eprom?
    i have a 27c128
    what would i have to get in the range of eeprom ? bigger better?
    aparently they can be erase with a programer with out a UV light?
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    best one to get is a 29c256, allows you to use the vr code if you want, and can still use vn code with no problems. but, good luck finding one thats a 28 pin, otherwise you have to rearrange some pins on the 32 pin versions.
    ive opted for a 28f256, its a 28 pin but still have to swap 2 wires around, but at least it fits under the blue cover.
    what sort of uv light is it? one of those ones that looks purple/black? im pretty sure it has to be a unfiltered uv light, the sun will do it, but take like a week, you can get uv erasers, but its much cheaper and easier to get a eeprom. cost about $5 each from www.futurlec.com.au for my 28f256
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    you can use a toothbrush cleaner from jaycar, with slight modifications to keep the UV light on
    i've been using one for months now!
    jaycar cat #: GH1507
    $9.95
    cheapest EPROM eraser i've seeeen!
    Luke.
  1. Erasing the service reminder on a VE
    By Julesgr in forum Holden Commodore How-To's
    Last Post: 07-04-2008, 09:08 PM
  2. how to program a eprom
    By RabidDog_12345 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2007, 10:11 AM
  3. eeprom help
    By ascension24 in forum General Discussion
    Last Post: 24-04-2007, 07:19 AM
  4. DIY $20 EPROM eraser
    By pete_pumpkin in forum General Discussion
    Last Post: 22-12-2005, 09:40 PM
  5. EPROM diagnostics
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2004, 09:48 AM
