Results 1 to 7 of 7
Thread: shorting starter motor
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default shorting starter motor
    hey guys, just finished putting my engine back together yesterday
    (did headgaskets, changed heads valve springs etc)
    now i put it back together properly...... and i didnt even touch the starter motor/wiring for the starter motor and u crank it over and it sounds like the solonoid is freezing then the relay in the fuse box goes crazy
    only things i can think of is
    1) starter motor is dead (grrr this is the 3d the car has had this year)
    2) theres a wiring short somewhere but ive tripple checked the wires and i cant see any
    3) something on the belt is jammed
    but it dosnt sound like the starter is even engauging..its just driving me up the wall im gonna put a spanner thru the windscreen soon
    the first starter motor just died like they do, u could get it spinning by cranking it and banging it with a hammer but not enough to start it
    the second starter motor didnt sound healthy since i put it in (2nd hand one) and died 2 months later
    the third one sounded like a industrial numatic drill (really healthy) and started the car really easily so it shouldnt be dead
    as far as i know nothing dripped down onto it that could cause a short but i could be wrong
    any suggestions would be awesome as im about to explode and destroy my car!!!!!
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    can you try another (known good) battery? can you try running a wire directly from the +batt terminal to the spade lug on the solenoid on the starter motor. (Ive heard a screwdriver can be used to short the fat +12v wire for the actual starter and the spade lug on the solenoid!)
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nah man battery is @ 12.3V, battery is less than a year old its a 550CCA 11 plate not a battery issue i dont believe
    but you Gave me a idea.... where exactly does the spade terminal wire run??? could i have crushedand shorted the wire when i took the engine apart???
    Oct 2006
    Kingston
    well as the crow flies, it goes from the starter motor via the starter relay to the starter switch.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    hrmmm... its gotta be the terminal wiring
    whats the wiring in terms of polarity????
    big fat wire = 12v??
    skinny wire = accessory 12V?
    and the whole things grounded?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by MyVPIsFasterThanYourVP View Post
    i take it back...... you were right.. battery was at fault.. the clicking sound was fuel pump relay (fuel pump not going on due to lack of power)
    Oct 2006
    Kingston
    Its sweet when the solution is a lesser evil! I'm looking at lifter/valve train tinkering soon, wish it was the battery!
    Left my oil change too late
  1. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  2. Urgent!!!! - Shorting Starter Motor!!!
    By PaRaDoX in forum Electrical Wiring / Questions
    Last Post: 26-11-2006, 02:53 PM
  3. Is this my starter motor?
    By dave.b in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-09-2006, 08:42 PM
  4. vp starter motor
    By joelandlisa in forum Electrical Wiring / Questions
    Last Post: 01-12-2004, 09:20 AM
  5. vc starter motor
    By marky mark in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-11-2004, 10:17 PM
