Results 1 to 16 of 16
Thread: Urgent--- Power Steering Issue
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Urgent--- Power Steering Issue
    hey guys...
    i recently put my engine backtogether
    the car drives now just got some small issues
    1. throttle spongy (just needs a tighten of hte cable)
    2. power steering issue
    3. air in brake lines (needs a bleed)
    ok now it was pissing out fluid because i forgot to put a seal back in
    now it makes funny noises when turning the wheel (has fluid)
    and stalls the car if u go too far, maybe i have air in the lines?? do u have to bleed it???
    need help please
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    vl commodore s2 rb30e
    Oct 2006
    to bleed it you need to turn it left and right slow with the motor on and leave the cap off where you put the fluid ive just done it too my car and the pump too and that what i was told too do
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    its actually air stuck in the pump..... dont worry it will work its way out
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by vl rb30e View Post
    Yeah, thats all I done and it all worked out fine.
    VR 3.8 Berlina
    Nov 2006
    since we're on the subject, i was wondering if someone could give me pointers on how to flush the power steering fluid altogether! i have used a syringe 3 times (just taking the stuff out of the resevoir and putting new stuff in) but each time about 10minutes later (of driving) it turns back to black...slowly getting a bit redder but mainly its dirty grey/black
    any suggestions? is it possible the fluid has never been changed or could something be going on in the pump...
    am i able to just release the low pressure hose on the side of the resevour and fill the resevour up while cranking the engine to make the pump work?
    any ideas would be great... its for a VR V6 commy
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Hmmmm, maybe if you undo the fluid lines attached to the steering rack? There is a small nut that holds the metal lines onto the rack, try undoing it and then jacking the front end up so you can move the steering wheel freely to let all the fluid squirt out.??
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Mack View Post
    Yep thats what I'd do.
    and 3 Dangerous non ABS VN's
    VR 3.8 Berlina
    Nov 2006
    oh yteah good idea! i never thought of jacking the car up
    what do you guys use to catch the fluid? or do you just degrease afterwards
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeha all fixed, filled up top today and its back to normal, airs still working its way out
    VT Berlina & mazda 2 DE
    Jul 2006
    To change power steering fluid...
    idle till fluid is warm. undo hose clamp under resevoir. Best to actually remove and clean resevoir by hand. Refit, refill. Idle till warm, redump fluid, refill, bleed and hey presto guaranteed clean system.
    Oh yeah I found it best to use a specific power steering fluid, as opposed to tranny fluid. Seems to get better results, particularly less groan.
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    Quote Originally Posted by bradcad View Post
    what fluid do you suggest?
    Jul 2006
    ok i've noticed there are a few made by different brands, such as castrol. I used one from my favourite oil mob, and I'm quite happy I followed their advice. From what I'm told by them the dextron is not quite the ideal fluid, used because it does the job and is easy to top up at service.
    Oct 2006
    Kingston
    My pwr steering pump is leaking from the back of the main pump. Its not any of the connections, or the reservoir. AAAArgh, is there something I missed or is this 'throw away and replace the pump' time?
  15. #15
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
  16. #16
    Jul 2006
    from memory (when my mate showed me) the back of the VP pump has a big circlip that holds the ass of the pump together- should be a seal behind it. (I think)
  1. ***URGENT HELP*** KDC-MP6029 Issue
    By broderikb in forum Car Audio
    Last Post: 21-02-2007, 07:16 AM
  2. Steering Issue *tricky one*
    By brockytt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 04:21 PM
  3. Wild steering issue
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-12-2005, 12:26 AM
  4. Power Steering Issue in 94' VR
    By tumoit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 08:48 PM
  5. Steering Issue
    By Phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2003, 06:27 PM
