Air/Con works fine but it keeps cutting off and on every 6 to 10 seconds which makes the car nearly stall??? Is it the Thermo and can i fix it ??
Yep change the thermo sender it is in the block just behind the altinator, easy job, did mine two weeks ago and now works like a dream.
Captain
Could also be low on gas & getting cut out from the high/low pressure switch.
Found problem...Bloody fan wasn't working
this isn't a rpoblem, but i noticed that wen i turn on a/c, a loud click (just once) as soon as i turn it on.
Al3x
Mines just faster cos its Red
