Results 1 to 7 of 7
Thread: Will a VQ Statesman L3 cluster work in a VP?
    nsladden's Avatar
    nsladden is offline GET UTED
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Sep 2005
    Murwillumbah
    Exclamation Will a VQ Statesman L3 cluster work in a VP?
    As the title suggests, will a VQ Statesman level 3 cluster work in a VP? Im aware that VR/VS ones dont so are the VQ ones the same?
    Thanks.
    I FRYED RICE!!!
    vl commodore s2 rb30e
    Oct 2006
    yes all the same but you can put the level 3 cluster in it will work as long as its for a v8 but the digital display wont work and too make that work i think you will have find a wreck stato or any commodore with the level 3 cluster and get all the wiring for the trip computer and the little plug that sits at the bottom of the level 3 cluster that makes the digital display work
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    you've got a 5ltr so its ll good... just make sure you check the PCB in case they dont fit... they should
    If you want to convert it to a l3, the instrucitons can be found here:
    Converting to a VN Calais dash
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    nsladden's Avatar
    Sep 2005
    Murwillumbah
    Thanks for help so far. Ive been told that by fitting a VR/VS cluster into a VN/VP you will cause a fire due to different wiring or something like that. Will i have that same issue with a VQ cluster? Thanks.
    I FRYED RICE!!!
    May 2005
    .....SE Burbs
    Pull both clusters out and read the PCB's.. THey have a map and connecter key so you can just compare the 2, if they have the same current connectors (123) then your good, if some wires vary then it may be a cut and shut job for you... they should be the smae but IM only guessing... just read the PCB's.. its NOT hard at all mate.
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Jun 2005
    installed a VQ dash into a VP executive a few weeks ago. had a few problems. youve gotta rewire connector 1, and the wiring for the switchblock is a little different due to the stato having a BCM and the VP exec not having one
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    nsladden's Avatar
    Sep 2005
    Murwillumbah
    Many thanks for all your help. I will definetly look into this VQ cluster now. Thanks.
    I FRYED RICE!!!
  1. Statesman cluster
    By Holdens Rule in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2007, 12:50 PM
  2. Will a HSV Cluster work with GAS??
    By mccar13 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-03-2007, 07:53 PM
  3. Will a cluster form a GEN 3 work in a V6?
    By IMCRZY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2007, 09:20 PM
  4. how to work the level 3 cluster
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 02:08 AM
  5. Will a V8 cluster work in a v6?
    By Ash81x in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 11:37 PM
