Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Help with removing plastic sides of vn commodore
    Vn Berlina 3.8 Auto
    Nov 2006
    Unhappy Help with removing plastic sides of vn commodore
    hi i removed the side black rubber bits with a heat gun and now i need to get the black glue that held it on,anyone got tips ? or has done it ?
    VN Commodore
    Feb 2006
    have fun. i hate the blue that holden used. not sure if it the same at the stuff they used for the badges. try some prepsole. not sure if it will work..
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Definitely NOT what they used on the badges.
    If you have a Berlina/S pack/SS or Calais you will have the big thick door trim like I did in which case I say give up.
    I tried EVERYTHING... and in the end I had to get all 4 doors repainted because i took all the paint off.
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I'm just about to do it on a door i'm painting up. I removed most of the sticky stuff with my nails and i'm going to try enamel thinners on the residue. I'll let you know how it works.
    Also, if anyone has any suggestions I can try them out on this door to see how they work as it doesn't matter if I bugger the paint up.
    Vn Berlina 3.8 Auto
    Nov 2006
    tried again and no good,tried turps and a razor and it didnt even budge,i think i might just have to sand them back and then respray them,so much for thinking it is a simple job
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Well the thinners did take the residue off but it took a lot of rubbing and soaking.
    This tar and glue remover is really good (it would definitely get rid of the sticky stuff) but no idea if you can get it here. Might be worth contacting them to see if they can supply out here.
    http://www.trafalgar.cc/used-car-product.php?id_prod=23
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I used a blunt paint scraper - 2mm flat front edge and built like a file. I had to use a bit of pressure too. Then sanding for a long time.
    Not a nice job but once you start.....
    and 3 Dangerous non ABS VN's
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by Shortstuff View Post
    What kind of strip did you have on the door? There is no way you got sikaflex off with tar and glue remover. It must have been a skinny strip, not a Calais/SS style strip.
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Quote Originally Posted by 1991_Vn2nV View Post
    It came off in 3 pieces and looked the same as the ones I have on my car. I didn't use tar and glue remover on this one, just enamel thinners. That tar and glue remover is wicked stuff though. It gets rid of most sticky shit.
    This is the kind of strip it was.
    JSTPOZN's Avatar
    JSTPOZN is offline S.A. The Defect State
    Air Bagged VR Calais, VLCT RB20, VLCT EFI V8 Turbo
    Dec 2005
    SA, North
    wow thats high...
    Why did you take them off? so have you got to paint it now?
    If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
    Go Here --->
    http://forums.justcommodores.com.au/...tml#post683835
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Quote Originally Posted by JSTPOZN View Post
    wow thats high...
    It's on a trolley jack in that pic, but it's not much lower than that! I parked next to a VN yesterday that had the top of the front wheels just in the guards - so embarrassing looking at mine sat next to it.
    I just took the trim off a replacement door I got so I can paint it up. Just put the pic up so 1991_vn2nv could see the sort of trim I took off
    1991_Vn2nV's Avatar
    Mar 2006
    I cant believe you got the sikaflex off that easy
    The double sided foam tape stuff is easy but then the 2 thick lines of sikaflex are horrible.
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    yeah no shit took us ages to get the vl calais ones off and 2 are still on we got bored there big square ****ers too
    Go Here --->
    '95 VR S2 BT1 5 Speed, N13 Pulsar Vector
    Oct 2006
    S.A. The revenue state!
  15. #15
    1991_Vn2nV's Avatar
    Mar 2006
    They're just the sticky foamy stuff I think. Piss easy to take off. Im going to take them off my VS soon and debage it... Although I like the series 2 badge.
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    I just took some Calais strips off a door thats going on my car tomorrow... Took me about 20 minutes to get it off... mostly time waiting for the jug to boil. Boiled water softens it up and you just rip em off. But getting the sikaflex itself off the doors is a whole different story.
    Heres what it looks like underneath with the sikaflex (ignore the silver...used to be Calais two tone):
    Attached Thumbnails Attached Thumbnails Help with removing plastic sides of vn commodore-argh-sikaflex.jpg   Help with removing plastic sides of vn commodore-argh-sikaflex-2.jpg
  17. #17
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Yuck. Looks like mine'll be a worse job than I thought - but I gotta take it off, it'll look awful with the bodykit on!!
  18. #18
    1991_Vn2nV's Avatar
    Mar 2006
    Yeah it does look aweful with a kit, thats why I took mine off. But you need to repaint your doors, it ends up being a necessity cause you wont get it off without hurting the paint.
  19. #19
    VP WAGON V6
    Mar 2006
    well the thin exec strips are held on by sickerfex as well. I have a small one of between my rear door and wheel arch. I want to take mine off but dont wanna have to persevier with the stupid glue!!!
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
  20. #20
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    hey vn2nv will i need to repaint my doors if its only an exec stripe? i didnt think i would because they have shit glue and practically fall off by thereselves hahahahaha thanks man =]
  21. #21
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Holy crap!! I didn't have quite that much sikaflex on the strips I took off. I wonder if somene had already taken the strips off and re-stuck them on mine.
  22. #22
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by padrickz88 View Post
    Nah, the sikaflex if thats what is used on the exec strips wont be as bad anyway. If its still sikaflex it will be a pain but possible. Im pretty sure its not actual sikaflex used on those ones, a glue like you said so it should be alright man There were some on my guards that just has crappy glue on the back... And they came off really easy.
    Maybe? My car was resprayed before I bought it, and they left the berlina strips off, so underneath it was like a faded colour white anyway with primer and stuff visible towards the edges. Lazy ass painters lol. So I would have needed to get the doors done anyway
  23. #23
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Go buy a Rubber wheel, Put it in your electric drill an use that.... Use it at work all the type on the black glue.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  24. #24
    VN Commodore
    Feb 2006
    aren't those rubber wheels only for 2pack. i reckon they bite into enamal a bit much.. could be thinking of somethign else though..
  25. #25
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by defa View Post
    Yeah when I took my car to a crash repairer to ask if they could remove the sikaflex they said its too hard on enamel paint as it gets soft when warm, where as 2pac gets harder the warmer it gets. They said they'd have to repaint the doors anyway themselves so I just took it off with no regards to paint and then sent it in to get the doors painted.
  1. Help removing plastic door strips
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 08:34 AM
  2. Removing the clear Odometer plastic screening
    By VZCrispey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-04-2007, 05:17 PM
  3. Help with Removing Plastic Storage Thingy(See Photo)
    By Crimpy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2007, 06:45 PM
  4. Removing cig lighter from plastic console
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2006, 11:58 AM
  5. removing plastic covers
    By bundy in forum Electrical Wiring / Questions
    Last Post: 01-06-2004, 10:10 AM
