Results 1 to 12 of 12
Thread: Misfire at idle
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Default Misfire at idle
    Ok, i've been having problems with my car idling since I got it, but it's got to the stage where i'm desperate to sort it out.
    It has a really annoying misfire all the time when it's idling, but it disappears almost as soon as I touch the throttle, and on some days it's a lot more noticeable than others. Most of the time it will almost stall when I put it into gear from park or neutral.
    I've changed things like the injectors, spark plugs, HT leads,fuel pressure regulator and O2 sensor and cleaned out the throttle body and IAC valve. Doing these things helped but only for a short time. It always goes back to how it was within a few days. Also using a lot of fuel but I don't know if that's related.
    Any suggestions? It's driving me mad!!
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    well this might sound weird but it was happening to me... but ever since i put my engine backtogether it stopped happening, i did a full gasket change.. but i was getting water into my cyclinders.... most do it for who knows why especially since i have NEW coilpacks, new leads new plugs etc
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    I'm just hoping it's NOT water going into the cylinders! It might be a possibility though since I seem to be losing a small amount of water somewhere.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Heavy fuel usage can be the temp. sensor. It may think the car is cold and rich up the mixture. Is the thermostat opening?
    and 3 Dangerous non ABS VN's
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Yeah, the thermostat is opening ok. Could the temp sensor also screw up the idle?
    VT Berlina & mazda 2 DE
    Jul 2006
    if you want to see if there is water getting into the cylinders- buy some chemiweld, use as per instructions, then if the problem no longer persists, you know what...
    Another thing to try is getting an oil test- should show up excessive water. About $35 for the test
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    have you changed the fuel filter? also check for vacuum leaks as they can cause excessive usage. also check the coils/dfi module as the engine will still run even if one of these is only marginally servicable. maybe try a compression test to see if you have a problem there maybe
    Body by Holden, Soul by Brock
    the Legend will live forever
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    I'll try to get hold of a compression tester and do that. What do I need to do to test the DFI module and coil packs? Never had a car with coil packs before so it's a bit of a learning process for me!
    I've not got round to doing the fuel filter yet.
    vp commodore
    Jun 2008
    change coil but youll have to find the weak one thats causing problem removing one at atime with insulated pliers and earthing same happened to my vp good luck
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    If its a definate miss then i would be steering towards an electrical fault like coilpack/dfi.
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    make sure you have a connected earth on your dfi module. mine was missing and caused me problems for months
    VPCalais38's Avatar
    VPCalais38 is offline VP Sleeper
    93 VP V6 Calais Series II
    Nov 2005
    Geraldton, W.A
    Where abouts is the earth for the dfi module?
    Guessing its one of the wires coming out of the plug?
  1. Vr Idle Misfire - Solution (i think)
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 07:33 PM
  2. vn misfire , higher than normal idle
    By andy71 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2006, 07:36 PM
  3. misfire?
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2006, 02:26 PM
  4. Misfire: likely causes?
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2004, 11:37 PM
  5. Vs Vr Misfire At Idle
    By stheggie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2004, 07:15 AM
