Results 1 to 18 of 18
Thread: errr 19s hitting spring seats
    VP WAGON V6
    Mar 2006
    Default errr 19s hitting spring seats
    well as the title says i got 19s and they are sccrubbing on the spring seats on the struts.. NOT happy jan.. lol how can i fix this???? should i just belt it up a bit with a hammer? Dont want to do that unless i have to though. My luck ill break it.
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
    VP WAGON V6
    Mar 2006
    oh there 245 tyres to.. that would be why they are hitting.
    - OWA650 -
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ummm yeah you kinda need 225's to fit under vn-vp guards and struts. unless you get coilovers
    VP WAGON V6
    Mar 2006
    lol hmmm an excuse to buy coil overs hey.. lol its not hitting the guards at all.. just the seats..
    - OWA650 -
    Boonz's Avatar
    Jul 2005
    then they might be the wrong offset also...how farr from the guards are they???
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by Peanuts Inc. View Post
    Actually 255's will fit with the right rolling diameter. He has 245/35's so the rolling diamater has increased... 255/30's will fit depending on offset. I run 245's and have no problems with the front and im on ultralows...
    Quote Originally Posted by Veeps Calais View Post
    spacers is all you need
    19's shouldnt hit at all
    How are spacers going to help? It is rubbing on the spring seat... So its the tread that is rubbing NOT the sidewall. Its not width, its rolling diameter. Yes the spring seat tapers up as it goes further out, but not dramatic enough for spacers to correct it.
    I went through all this about a month ago. Originally I thought it was rubbing on the strut, but then when I got to have a decent look it was the spring seat.
    Anyways I also run 245/35 R19's and after a wheel alignment I was left with 5mm clearance to the spring seat. So give that a go but offset will have an effect on this too I think.
    Your other option is correct sized rolling diameter. No 30 profile is available for the 245 width but you can go back to a 235 width or up to a 255 where SOME tyre manufacturers do a 30 profile (most are 265 though).
    Jan 2006
    Willall Racing
    spacers will solve offset issues..
    and ive been there and done that with these same issues with both 19's and 20's
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    didn't think the spacers are legal however?? hope you fitted longer studs with those spacer though. not all treads are made equal either if you put 2 treads together from different manufacturers of the same size you will find there is a difference in width, sidewall height etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by immortality View Post
    Yeah spacers are illegal... But I think you can go up to 5mm spacers without using longer studs... or atleast thats what I've been told.
    It will be touching in the inside top of the spring seat. Spacers will simply move the rubbing further out onto the spring seat.
    Pedders fitted 5mm spacers to my car when I had this problem and it solved nothing. I tried spacers because I thought it was the sidewall hitting... as in rubbing the strut. But in the end it wasnt.
    JSTPOZN's Avatar
    JSTPOZN is offline S.A. The Defect State
    Air Bagged VR Calais, VLCT RB20, VLCT EFI V8 Turbo
    Dec 2005
    SA, North
    Spacers are very dangerous and put alot of strain on the studs....
    The rims shouldnt be on the car if spacers are needed.
    If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
    Go Here --->
    http://forums.justcommodores.com.au/...tml#post683835
    VP WAGON V6
    Mar 2006
    yeah im not using spacers.. had issues with them on a mates ccar before. But we wont go there. The tyre is rubbing rite where the hole is on the spring seat. There is a 5mm gap there but on long sweeping corners all i can smell is rubber and its worth to much to be burning.. lol. The problem is the tyres are to wide i think. If i went down to a 235 i recon it would solve it so when these tyres eventually die ill be putting 235s on the front atleast and might put 255s on the back.. hehehe.. The tyre is sitting nicly with the guard to.
    Oh and spring size has nothing to do with if its going to rub on the spring seat or not. Due to the fact that its a fixed length. If i could just cut it and add 5mm to it it would be all good. But for some reason i think that might be a little illegal.. lol
    - OWA650 -
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by JSTPOZN View Post
    coming from someone with cut springs......
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    Show me my cut springs..
    Coming from someone with broken studs cause by ,,,,,
    Go Here --->
  15. #15
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by commy92 View Post
    If you get 235's you can also get the right tyre profile, altho a 235/35 is smaller in diameter than a 245/35 also, as its 35% of the width, so yes that will fix the problem. Im going 255's front and rear just so I can rotate the tyres, 255/30's though, not 35's.
  16. #16
    VN S2 Berlina Wagon
    Apr 2004
    Why dont you get a wheel alignment like Vn2nV said considering you have a similar setup to him. I'm not sure what its called but you can get a wheel alignment where they move your struts etc.
  17. #17
    CURSD VP
    Jun 2006
    Quote Originally Posted by lazza44 View Post
    that wont do anything, the stub axle and strut is one unit so you cant change the fact that its hitting the spring seat.
    Put a 235 or 225 tyre on it. Dont use spacers, why do poeple always recommend spacers!? They are dodgy/illegal/unsafe for a reason.
  18. #18
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Are they a HSV wheel or an aftermarket one? With a HSV wheel the biggest we have been able to fit is a 235/35 and it will 'just' touch on max compression. With an after market have fitted a 245 without any problems at all.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
  1. bonnet hitting windscreen
    By WhiteLightning in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2007, 08:36 PM
  2. Wiper arm hitting bonnet
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2006, 02:52 PM
  3. Ferrari after hitting a telephone pole at 200+
    By kowan in forum Jokes/Humour
    Last Post: 15-05-2006, 02:01 PM
  4. VK ...errr....RWC Issues
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-03-2006, 11:54 PM
  5. hitting netural
    By walace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 04:49 PM
