Results 1 to 19 of 19
Thread: blown o2 sensor??? code 44
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default blown o2 sensor??? code 44
    hey, ever since i put my engine back together ive been getting a
    code 44 error: Oxy sensor overvolting...
    cars been running really rich and using 20L/100km
    i did the o2 sensor recently but maybe its broken?? was passing some water through the exhust before i took it apart
    anyway i know they'res more than 1 error for o2 sensor (code 13 aswell)
    any thoughts??
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Temp sensor? if it thinks the car is cold it gives it more fuel....
    and 3 Dangerous non ABS VN's
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Code Explanation
    12 No spark pulses at CPU or else good system, no codes
    13 Oxygen sensor output remained at .35-.55 volts for more than one
    minute after warmup. Possible open circuit.
    14 Coolant sensor indicated a temperature above 130C for 3 seconds
    after engine ran for 20 seconds. Probably a short
    15 Coolant sensor indicated a temperature below -30C for 3 seconds
    when MAT > - 13 or engine running over 1 minute. Probably open
    circuit
    21 Throttle pos sensor above 2.5 volts for 2 seconds when engine
    speed below 1600 rpm
    22 Throttle pos sensor below .2 volt for 2 seconds while engine running
    23 MAT sensor shows < -30 degrees C for 3 seconds after engine
    running 1 minute or coolant > 30C. Probably an open circuit.
    24 No speed sensor pulses when engine between 2000-4000 rpm,
    throttle closed, high vacuum, not in neutral and all for 5
    seconds
    25 MAT sensor showed above 145 degrees C for 2 seconds after
    engine ran for over 1 minute. Possible short circuit.
    31 Unknown Error Code
    32 Unknown Error Code
    33 MAP sensor voltage too high (> 4.00 v). Possible vacuum leak to
    sensor or faulty sensor.
    34 MAP sensor voltage too low (< 0.25 v) with ignition on or
    engine running >1200 rpm and throttle open >20%
    35 Closed throttle idle speed is more than 75 rpm above or
    below correct value for more than 45 seconds
    41 No Crankshaft reference pulses. Ignition voltage < 11 volts etc.
    42 Open or short on EST or BYPASS line to ignition module.
    43 Engine Knock Sensor open or shorted.
    44 O2 sensor showed < 0.250 volt for over 20 seconds while
    operating closed loop
    45 O2 sensor showed > 0.550 volt for over 50 seconds while in
    closed loop with engine running over 1 minute and throttle open
    more than 2%
    51 Check insertion of MEMCAL in socket and bent pins.
    52 Check that CALPAK is in place, fully inserted, and no bent pins
    53 Car's alternator has produced >17.1 volts for over 2 seconds.
    Check charging system
    54 Unknown error code
    55 ECU A to D error. Check ECU grounds, or excessive input voltage
    Trouble codes by fault type
    Problem Code(s)
    NO problem 12
    Oxygen Sensor 13, 44, 45
    Coolant Sensor 14, 15
    TPS (Throttle) 21, 22
    MAT (Temperature) 23, 25
    MAP (Pressure) 33, 34
    Speed Sensor 24
    Crankshaft Sensor 41
    Spark timing 42
    Knock Sensor 43
    Memcal problem 51, 52
    Alternator overvoltage 53
    Control unit input 55
    the sensor is less than 5,000km old.....
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    the oxygen sensor is only theyre for a basic reading of what goes on it dosnt controll much of the fuel mixtures its more based on the coolant temp sensor
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by xcop5l View Post
    ohh k.. well its running VERY rich, can smell the petrol in the air...
    how much do new temp sensors cost???
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by PaRaDoX616 View Post
    Not much from the wreckers (best place for cheap VN bits) $10.00 maybe.
    Dont know what they are new - but if you have to get 1 from Holdens take an arm n leg just in case...
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    VT SS 5.7
    Aug 2006
    Western Suburbs/Melbourne
    What oxygen sensors do link :http://www.autotap.com/oxygensensors...n_sensors.html
    Theres the link too what oxygen sensors do,ive just changed mine and for the $40 dollars i paid for it i will easily get that back in full, on petrol savings
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    You should slap whoever told you that rubbish. The oxygen sensor is an important part of closed loop fuelling & is the only feedback the computer recieves directly related to combustion.
    As for the sensor problem. If there was still moisture in the exhaust & it got on the sensor when it was hot it will destroy the sensor.
    The other things you can check are the map sensor,fuel pressure, oxygen sensor vent & earth circuit.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by vt1538 View Post
    VN's only use a narrowband sensor which means it's basically just a rich/lean switch and the signal is only directly used for fuel metering at 14.7:1, I think that's kinda what he was trying to say. A faulty coolant temp sensor can have a fairly disastrous effect on mixtures and provides a plausible explanation for the symptoms described, that is if the code was as originally described, "overvolting". In fact code 44 is undervolting, registering lean. If the sensor is reading lean and the fuel consumption is through the roof then logically the O2 sensor is the likely candidate.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    Quote Originally Posted by pandaman View Post
    Only a very few of the later model cars use a wideband sensor as they are an expensive item. The narrowband as you say is only accurate at stoich so is used as a lean/rich switch to control fuelling. However the computer will trim the fuel if the narrowband isnt switching properly. If the voltage remains low it will add fuel, if it remains high it will remove fuel. These trims will stay in the computer until reset or the problems are fixed. Since no two engines are the same this is how the manufacturers have been able to run a generic tune to suit all the engines in different conditions & different wear limits.
    I agree that the o2 sensor is the likely candidate, but there are a few other issues that can be easily checked first.
    VN CALAIS/VT executive
    Sep 2005
    any thoughts??
    isn't code 44 dodgy ECU?or is that code 45
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i've recently been getting faults too, haven't checked the codes yet, but i'm fairly sure it's O2 (happened since extractor install)
    it seems to come on more if i'm using cruise and the engine is on low revs.
    as i said, i've heard extractors often cause 02 sensor problems, is there any way to stop this, or an 02 sensor replacement that will fix the prob?
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    The problem with extractors is the O2 sensor does not get hot enough to give a reading consistently. You can try heat wrap on the exhaust around where the sensor sits or a later model 3 or 4 wire O2 sensor with the heater circuit.
  15. #15
    Sep 2005
    You should slap whoever told you that rubbish. [Quote]
    never had any troubles with O2 sensor and extractors in my time with VN's or any other car for that matter
  16. #16
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    [QUOTE=samuels;565111]You should slap whoever told you that rubbish.
    HAHAHA
    It is actually a common issue with a few makes & models that fault codes start showing after the fitment of extractors. It is all to do with the sensor being in a colder part of the exhaust stream & not getting up to temp fast enough. Power3lave wasnt talking about code 44 he was talking about a code immediately after fitting extractors. More than likely code13.
  17. #17
    Sep 2005
    [QUOTE=vt1538;565189]
    Quote Originally Posted by samuels View Post
    HAHAHA
    not saying it doesn't happen ,but in my 25 years of fitting extractors(O2 sensors were only just coming in mid 80's)i haven't experienced as many faults as described,i have come accross probably 2 and they were actually dicky O2 sensors,replaced and all good.
  18. #18
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'm with samuels, 18 years of fitting extractors, the sensors that need replacing were buggered anyway, the extra flow created by the extractors just made the error show up. A lot of engine light issues in later model cars were due to the shift points being changed in the transmission.
  19. #19
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    So PaRaDoX616, has this issue been fixed by swapping sensors from your other engine?
  1. fault code 13: oxygen sensor?
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2012, 07:08 PM
  2. Fault code 13 O2 sensor
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2006, 03:17 AM
  3. Code 72 Vehicle speed sensor
    By Notorious in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 01:26 PM
  4. ECU Code 13, Oxy Sensor
    By pro_gmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 11:06 PM
  5. Fault code 13 - o2 sensor
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 10:46 AM
