as the title says, my heater fan only works on 3 and 4 speeds. i have changed the risistor under the plenuim chamber i just cant be stuffed pulling the switch out and testing it all.
has any one come accross this or has any one found a way to fix it
im thinking its the switch its self.
my cousins car has the same problem, so if i find out how to fix it i can do his 2
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
if you can't be assed pulling the switch out, you could try spraying some of that contact point cleaner stuff in there, then wait a while for it to clear out, then give it a shot.
i don't think you have to wipe the contacts down after using it, but read the directions to be sure
Prob dead switch. Has died on me too. The wreckers said it was a common fault. $10.00 for a replacement and all was good.
and 3 Dangerous non ABS VN's
MY RIDES
[SIGPIC][/SIGPIC]
Mines got the same prob. the heater or aircon is either blowing me away or not working at all.
Australia. Love it or leave it
Yeah mine only works on 4... I bought a VS resistor from Holdens, the newer style, but didnt fix it. Better than the shit VN one anyway so it wasnt a TOTAL waste.
exactly where is the resister? mine only works on 3-4 haha 1-2 doesnt work at all... haha
Are you sure that the resistor you put in wasnt faulty as well? Ive been through 2 resistors untill i found one that worked. I currently have a Camira resistor installed. Works fine on all speeds.
I FRYED RICE!!!
yeah i know its not the resistor because i bridged the treminals on it to make sure and i did a resistance test on the new fan resistor.
MY RIDES
[SIGPIC][/SIGPIC]
Replace fan switch. Common problem, contact strip burns out. Not a big job.
**NEWSFLASH**
The makers of VIAGRA have released the product in powder form. Add to your cuppa in the morning............stops your biccy's from going soft.
had the same prob with my (non climate control) vp exec - the resistor assy (which is under a black plastic dome which is under the panel in the engine bay where the windscreen wiper shafts protrude thru) was burnt out - newey ex holden about $40. not sure if climate control has the same set up.
