Hi I have a 92 VP station wagon Ac works fine on most days but when the weather warms up it starts to blow fuses, checked thremo fan and swapped relays around belled the wiring loom out but nothing to show for it anyone have any ideas
Blowing the A/C fuse? or other fuses?
and 3 Dangerous non ABS VN's
Fuse that blows(10a) takes out the Thermo fan,the heater blower fan, and the A/C.
Something is shorting out - I'd try disconnecting the fan for a bit to see if it still blowes the fuse. Be careful not to cook the car!! Also u could try swapping the relays around. eg lights & horn with the a/c & fan.
Tried that no joy the thermo fans checks out ok with a meter as well, only fan I haven't checked yet is the heater blower fan but that works fine by its self suspect something is about to die but is just hanging in sigh! Thanks for your help
you may want to check the clutch on the A/C pump it may be earthing out..
