Hi,I've been having trouble with my VN If I cruise around at very low revs no problem. Frequently though say every 5 to 10 times when I try to accelerate even moderately hard she cuts out and I have to stop and turn it off before it will start again. She can also be a bitch to first start. I put into the workshop and they said crankshaft sensor replaced it and said it was fine (obviously didn't give it much of a road test. I've checked the fault codes and after clearing cranshaft sensor, MAP and temp faults despite still getting cut outs I now show code 12 no fault. Oh wise and noble VN lovers what is going on?!!
fuel pump is on its way out
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
Could be the ECU, DFI or any connection to do with them. (also the fuel pump too.)
Have you replace the plug leads/plugs?
and 3 Dangerous non ABS VN's
Sounds like my old white one was doing right before the fuel pump died. That'd be my bet.
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
Or, your fuel filter could need replacing.
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
:: hakhawk :: says:
Thanks for the replies
I have looked at the leads and they seem fine. I mean the thing stops dead as if it was switched off no cough or splutter.
I'll check the fuel pump pressure tomorrow and hope thats it.
Ok
Replaced the fuel filter, checked fuel pump pressure, checked map sensor, checked throttle position sensor, checked relays, tried another computer and it still does it. Going for EFI unit tomorrow, going for a beer now.
TA-DAH!!!!
DFI module intermittent fault
Thankyou Lord VB source of all inspired ideas!!
Thankyou to those who have contributed!
