Results 1 to 4 of 4
Thread: vn wagon misfiring
    vn exc/vtss
    Oct 2005
    Thumbs up vn wagon misfiring
    Hi all just wondering if anyone could help me.This is driving me crazy.My vn wagon only misfires after travelling 100ks or so.I usually go to melbourne once a week.Its fine on the way there which is around 110ks.On the way home it starts misfiring badly.Its not a one off,its happened every week for four weeks now.Its not a fuel problem because it does it on gas too.Could it be the coil pack?I have changed the plugs and leads and it sill does it.Just wondering if anyone else has had this strange problem.Thanks for a great website guys
    VN executive v6 3.8L
    Nov 2006
    yeah mate, mine was misfiring pretty bad when i brought my vn. it ended up being the coil, but mind you it had shit loads wrong with it, and it needed a new fan belt, harmonic balancer, spark plug leads, radiator cap, wiper motor etc etc.. and all that was only $470 from a mechanic.. execpt for the harmonic balancer that was changed by me..
    if you know how to change the coil pack and dont mind experimenting give it a go, but you probably dont want to spend money on things you might not need.. but yeah a new coil did my car wonders.. and she runs beautiful now
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    I had a similar problem with my VN last week, also on gas. Mine ran on five cylinders all the time from cold though.
    I replaced the crank angle sensor (CAS)which fixed it but then my coil died.
    If you are sure the plugs and leads are good test the coil first and then the CAS. Many times the coil will test fine unless the motor is under load though.
    Because it occurs after a lengthy trip and obviously when the motor is hot it sounds like the CAS.
    Next time it happens pull over and pour some water over the CAS and see if it improves.
    That is not my own idea but one that is suggested in many threads here and helps identify a faulty CAS.
    Never
    $50.00 paid for each answer to a post of mine.
    Please note cheques will not be honoured
    vn exc/vtss
    Oct 2005
    Red face its fixed
    Thanks for the replies.It turned out to be two ignition leads.The car shit itself 100 ks from home.I had no tools and only 100 dollars.I walked to the nearest repco and bought a set of leads.And it runs well now,but I still can,t figue out why it only did it after travelling 100 ks or so.Thanks for the help guys.
  1. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  2. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
  3. VN Misfiring
    By LMac in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 01:31 AM
  4. misfiring
    Last Post: 18-06-2006, 11:36 AM
  5. misfiring....
    Last Post: 29-04-2006, 06:06 PM
