Results 1 to 4 of 4
Thread: Can someone do me a favour?
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Default Can someone do me a favour?
    As the title says! I just wondered if someone with a V6 VN that runs well could hold a screwdriver on to the body of each of their injectors while their car is running- you should be able to feel them pulsing through the screwdriver, and what i'm wanting to know is if they all pulse about the same.
    Two of mine seem to be pulsing much weaker and a bit more erratically than the others but it's the same one on each bank (middle one on the L/H and R/H heads) so I wondered if it was normal. I don't want to start changing injectors and fiddling about with wiring if I don't need to be!
    Thanks!
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    mine are of all equal strength.. they all felt the same to me.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Ok. Thanks a lot for doing that! I guess i'll try changing those injectors tonight, and hope that works.
    May 2005
    .....SE Burbs
    Swap the injector for one next to it and see if it does the same thing!
    and your welcome!
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  1. Favour, please?
    By BoostedDave in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2007, 08:40 PM
  2. A Favour (VT/VX/VY/VZ)
    By vn88calais in forum General
    Last Post: 22-06-2006, 11:57 AM
  3. Can someone do me a favour
    By AirStrike in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 10:05 PM
