Results 1 to 12 of 12
Thread: Maybe a stupid question but still
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    Default Maybe a stupid question but still
    OK, Did Series I VN V6 Autos come with a seperate trans cooler? and
    What RPM should my car sit on at 100km/h?
    I have searched but found nothing.
    Reasons: My Series I VN Lexcen has a seperate trans cooler, a radiator with a cap and no inbuilt cooler and since fixing my CAS and coil my tacho works but shows 2100rpm at 100km/h.
    I believed it should be around 1800rpm at 100.
    I also have a Hayman Reece style hitch so was thinking there may have been a towing pack available but that doesn't explain the revs.
    Never
    $50.00 paid for each answer to a post of mine.
    Please note cheques will not be honoured
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Nah they didnt come with a seperate trans cooler. And at some point you've had your radiator replaced, with a series 2 one obviously. Which is the sensible option imo.
    2100rpm is a bit high or think if its in Blue D. Is that the D you have it in at 100?
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    In fourth, 2100, that is if the tacho is correct.
    Did the Series II radiator have the inbuilt trans cooler?
    My car also gets off the mark exceptionally well compared to other VN/VPs I have come across, through family, recently.
    Never
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by Pretender View Post
    how long have you had the car? diff gears? i think mine does 100 @ 1900rpm (mine is a series one)
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    I might check the accuracy of the tacho and then attempt to check the diff gears. It might explain why it goes as good as or better than when new despite having the weight of a gas system in it.
    I've had the car for a little more than a year.
    Never
    1991_Vn2nV's Avatar
    Mar 2006
    If stock 3.08 gears sit on 1900rpm at 100km/h then...3.45's would be sitting on 2125rpm at 100km/h
    So maybe you have VL diff gears in your VN?
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    Makes sense, I'll check it out on Wednesday. My wife is using it tomorrow.
    Never
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    What about the 5spd box?? mine sits on about 2000rpm@100km/h. Does this sound right?
    1991 vn series 2 exec [URMONY] & 93 vp calais
    Apr 2006
    melb
    yeah mine is series 2 but at 100 in overdive it is exactly the same revs and yes i have a 3'45 ratio centre
    ~~Nic~ says:
    yeah feel dick tho
    VP Executive R-spec
    Jan 2005
    I think you will find that all Lexcens had the transcooler and the Commodores did not, If you still have the 14 inch wheels on it and they are a bit worn or you have a slightly smaller profile than stock you will see 2100 and yeah the little wheels have the same effect as 3.45 gears over the 1/4, My Lexcen also came with the 2 ton rated Hayman reece bar (it's massssssive)
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    it does sound like you got the 3.45:1 ratio diff gears and the seperate trans cooler is agood thing as the standard transcooler in the radiator is very marginal at best anyways. someone's done the work for you already.
    Body by Holden, Soul by Brock
    the Legend will live forever
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    Checked it all out. 1900rpm @ 100km/h now so I guess it has the standard diff.
    Never
  1. Stupid Question
    By hitman1979 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-05-2006, 06:39 PM
  2. Stupid question?
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2005, 04:01 PM
  3. Stupid Stupid Question
    By habro in forum General
    Last Post: 24-09-2005, 11:51 AM
  4. Stupid Question!
    By tr3nt in forum The Pub
    Last Post: 02-09-2005, 05:20 PM
  5. Stupid Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2005, 12:25 PM
