Can i simply swap over rotors, calipers and wheels from the front of a VX to my VP without any other mods? I can have this setup for free only if i can put
the VP setup back onto the VX... The VX will endup being sold off for scraps
anyways, Just needs to run safetly for a few more kms...
Cheers.... Thanks in advance... Top forum... Very helpfull.....
i don't reckon it is too possible. look on ebay. there is kits there. i don't know much about it but i don't think it is a staight swap
You need hub adaptors and modified brake lines, the brake booster and master cylinder.
you difinitly need the adaptor and mod brake lines, you can get way without the booster and bigger mastercylinder but you will have a lot of pedal travel. most people who do this conversion stick with there original brake booster but fit the larger 1" master cylinder of the V8 model which is a direct bolt-on job
Body by Holden, Soul by Brock
the Legend will live forever
bungle the vp has studded rotors with wheel bearings w/as the vr to vz has floating hats [that is the rotors glide over the studs ]you would have to do a strut conversion as the vr changed the strut bearing config and lost the vn/vp hub bearing spindle, have heard of sport struts that can go into vn with vt style hubs but cant remember where to get them sorry
If i wanted to break ya balls i woulda kicked ya girlfriends handbag
