Results 1 to 14 of 14
Thread: Gasket removal
    VP Commodore
    Nov 2006
    Default Gasket removal
    anyone know any tricks to remove stuborn gasket remains? maybe using some liquids? or is the old scrpe off with chisel/flathead the only way?
    VN Commodore
    Feb 2006
    a scraper is usually the best way.. something nice and flat and sharp. but not too sharp or it will loose it's edge too quick.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    what's the gassket on? on my thermostat gasket i used wet/dry sandpaper, just make sure you don't get any filings anywhere bad.
    VP Commodore
    Nov 2006
    VN Commodore
    Feb 2006
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    an aluminium paint scraper is good, because it's softer than the cast iron block, it may need resharpening every now and then but meh, a small price to pay to ensure you don't score the sealing surface. Once you've got most of it off, hit it with some 600 grit wet & dry paper and finally a bit of clean rag and some solvent of your choice (I'm a fan of turpentine personally). Just before you put it back together again, hit it with some more 600 grit to remove any corrosion that's started to form while it's been apart, maybe a final go with some 1200 grit just to be sure, to be sure, to be sure! Then whack her back together. If it leaks the bugger's gotta be warped because you know it was clean.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    if you want 2 remove old gaskets 2 a smooth surface (eg rebilding the motor) you can use a drill and wire brshes on it, Works a treat
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    razor blades are the go ... sandpaper id be bloody cautious of if your using a coarser grade .. metal filings and engines are not compatible
    never late in a 3 0 .. uhhh ... intercooled turbo
    yes i drive an mx6 turbo ... its probably quicker than yours.
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by s0sage View Post
    Hence why I said 600 and 1200 grit. You don't exactly remove a lot of metal with it, hell it barely moves old gasket gunk.
    VP Exec,Gsx-R 750
    Mar 2005
    Permatex make a spray on gasket remover. Spray it on, leave it for a bit, usually it scrapes off pretty easy afterwards. Snap On make a good gasket scraper, if you can be bothered forking out for one
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by Hillerus View Post
    The spray on gasket remover works pretty well, the good stuff is kinda expensive though. It's very useful if you've got a lot of baked on gasket to remove.
    VP Exec,Gsx-R 750
    Mar 2005
    Yeah, it is. Best part is though you can let it sit for a while, so you can go get pissed or whatever, come back in the morning, attack the gasket with your scraper, and watch it peel off
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    Old blades off a power hacksaw sharpened up what ive used for years.Cut 70mm off one end and sharpen it like a chisel single bevel stay sharp for years and the round end fits nice in ya hand just dont heat it to much when you cut and sharpen it or it will lose its hardness get it as flat and sharp as you can
    VP WAGON V6
    Mar 2006
    wizzer!!!!
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
  1. gasket tip
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2010, 09:37 PM
  2. vs v6 sump gasket removal
    By 308commodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2007, 07:30 PM
  3. V6 Exhaust Gasket
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2007, 08:08 AM
  4. blown gasket?
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 04:30 PM
  5. VRS Gasket Set?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2006, 08:02 PM
