Results 1 to 7 of 7
Thread: 91vnspak thermo not working
    vnspack91 is offline duddles
    91 vnspak
    Dec 2006
    salisbury
    Default 91vnspak thermo not working
    has anyone know what things i should check on vn to get thermo working
    VN SERIES 2 V6 T5
    Feb 2009
    VN SERIES 2 V6 T5
    Feb 2009
    VN SERIES 2 V6 T5
    Feb 2009
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    replace both coolant temp sensors, go from there.
    edit: I say both because one outputs to the ecu, one outputs to the gauge on your dash... I can't remember which is which, my bad. anyone?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    try putting it in diagnostic mode it should come on if it doesnt then possible relay or the plug isnt in or thermo stuffed if it does then possible sensir
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    i had the same issue and i just wired it to a switch i prefer that anyway then i can control the temp on the strip myself
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  1. VS thermo fan relay not working... HELP!!
    By gigaz83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2007, 03:48 PM
  2. Thermo Fan not working
    By Gambit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2007, 11:09 PM
  3. thermo fan not working
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2006, 10:20 PM
  4. thermo fan not working
    By paul 11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2005, 06:19 AM
  5. Thermo Fan Not Working
    By flames in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2005, 08:00 PM
