Results 1 to 8 of 8
Thread: crank jamming VP
    VP Commodore
    Nov 2006
    Default crank jamming VP
    whats the best way to jam the crank in a VP commodore? i heard you can jam it by taking the starter motor off and jamming something into the flywheel? is there any other way besides taking the sump off.
    its automatic.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Take the starter motor off and jam the ring gear by engaging a tooth with a flat piece of metal. Works a treat.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    VP Commodore
    Nov 2006
    tryed that dropped the metal plus an alen key into the chamber now i havbe to remove the plate gay.
    would it be pretty easy to jam it with the plate off?
    VP Commodore
    Nov 2006
    man i tihnk i migth have threaded the crank shaft bolt to a degree where the crank is screwed is this possible?
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by Meerkat View Post
    It's possible that the puller may have distorted the thread. Never fear though, even if the thread is munted it can be rectified (I think). If the bolt just won't bite then you may have to retap the thread, this can be done in situe, there's plenty of room. Never done it on a crank but I can't think of any real reason why it wouldn't work. Seeing as it's probably only the top of the thread that's squashed, I'd be getting in there trying to clean it up enough to get the bolt to bite before doing anything drastic though.
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Hmm, dunno. Try it with a long bit of metal next time though. Easier to retrieve if it goes walkabouts. Sounds like this is turning into a bit of a bastard job for you.
    VP Commodore
    Nov 2006
    yeah it is. hmmmm the bolt does bite i got it in a bit but i cant screw it in anymore easily i need to use force which is why i need to lock crank to get it moving again.... im tihnking if i jam the crank and then use a big breaker bar it will be ok? as long as i get it in? is this the smart option or should i do something else first?
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Well that's interesting, if the puller had stuffed the thread it probably would have squashed the top, so if the bolt is going in a turn or so and then stopping I'd be getting the torch and looking very closely at why it's stopping, could be something as simple as a piece of junk caught in the thread. I'd be jamming the crank to put the bolt back in anyway, because you're gonna have to jam it to get the bolt torqued up right.
  1. FS: 351 crank and mags QLD
    By Jaym in forum Parts And Other Items For Sale
    Last Post: 27-07-2006, 09:45 PM
  2. VN crank questions
    By potshots007 in forum V6 Development And Modification
    Last Post: 17-06-2006, 10:22 PM
  3. L67 Crank
    By ADZ124 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 05:49 PM
  4. SV6 Auto jamming
    By Jordo1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-01-2006, 07:17 PM
  5. engine won't crank
    By vs_ute_chick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 10:36 PM
