Results 1 to 20 of 20
Thread: Um Wheres My Aircon Gone?
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    Default Um Wheres My Aircon Gone?
    hey guys.. i had my aircon running yesterday.. was working mint.. i stopped off at maccas and grabbed a drink, when i went to put it back on WTF! hot air coming out! um i had it regassed just this year and tested for leaks.. and now its just putting out hot air.. does any one no whats going on with it? is there a fuse or something i might of done? without stating the obviouse solution of getting a regas.
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    have you checked your heater tap??? it doesnt make sense that it just stopped all of a sudden??? can you still hear the compressor clutch cut in and out???
    Keesh's Avatar
    Jan 2006
    yer i can hear something.. its like its runing for a second or 2 after its turned off.. the compressors working im guessing cause the motor still struggles when i put it on.. its like its working but theres no refrigerant. its weird and it doesnt make sence.. it had to happen on the 2 hottest days in melbourne.. i cant drive n e where with my leather interior
    Boonz's Avatar
    Jul 2005
    turn the temp dial to full cool, go out into the engine bay and make sure the heater tap is fully closed and the vacuum line is still on the actuator
    Keesh's Avatar
    Jan 2006
    i reeli dont no where the heater tap is??
    Boonz's Avatar
    Jul 2005
    its where the 4 hoses join from the water pump, its in between the drivers side exhaust manifold and the brake master cylinder.
    it doesnt sound like the air con is out of gas, the compressor wouldnt cut if there wasnt any gas
    Keesh's Avatar
    Jan 2006
    yer the lil thing with a vacuum hose off it.. how do i no if its opening closing?
    i turned the dial and it seem to stay in the one position
    Boonz's Avatar
    Jul 2005
    well does the air temp get hotter at the vents when its open or does it stay the same???
    Keesh's Avatar
    Jan 2006
    no difference at all.. its all hot.. i presed it closed under the hood and it pops back so im guessing it needs vacuum to open/close?
    Keesh's Avatar
    Jan 2006
    its opening and closing.. but its all still hot
    Boonz's Avatar
    Jul 2005
    ok, so i think somehow the control has been knock or a vacuum line split, im pretty sure it needs vacuum to open so maybe a quick fix is to take the vacuum line off the heater tap and block the line with a screw or nail and see if it changes the temp at the air vents.
    Keesh's Avatar
    Jan 2006
    blocked it haha.. if anything it felt hotter.. im thinking now that it is air con related..
    Boonz's Avatar
    Jul 2005
    Keesh's Avatar
    Jan 2006
    im not to sure.. its hot as **** here in melb and the engines producing some massive heat even after 5 mins.. so im guessing its just outside air.. if i new a bit more about how the aircon actually worked id probly b able to check everything.. whats the blower in the passenger footwell do? and is the massive black cylinder under the hood hold the gas? the compressor could have shit itself couldnt it.. but it does put strain on the motor still so i assum its doing something
  15. #15
    Boonz's Avatar
    Jul 2005
    compressors rarely shit themselves.... usually its from hydraulic lockup in the compressor from when the liquid doesnt turn back to vapour before it gets to the compressor...if that happens then your engine usually stalls so i dont think its that. i think you should take it back to where you got it regassed and get them to check for a problem with the heater controls and then for leaks around the seals and compressor.
  16. #16
    Keesh's Avatar
    Jan 2006
    hmmm.. i wish it didnt have to come to that.. i had it done the same time as the rwc.. its like an hour drive.. in this heat haha.. i was reeli hoping to solving the problem today.. damn!!!!
  17. #17
    adam69 is offline Banned
    VT Clubby
    Oct 2004
  18. #18
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    to see whether the heater valve is working turn it all the way to cold and feel the copper pipes ut the left of drivers feet. turn on cold b4 start car and run it for a while 5 min or so and when u touch them u'll burn your finger if u touch it for too long (96C or something) if that is the case its heater valve. to see if its getting cold touch the thingo in the left corner of engine bay closest to passenger side there is this alominium contaner thing called an accumulater i think(just follow the pipe from the condenser if u cant find it) that gets freezing if its working.
    13.3 1/4 exhaust only untuned!
  19. #19
    Keesh's Avatar
    Jan 2006
    yer see thats not cold, its staying warm.. theres cool air when its on cool and hot air when its on hot.. but no freezing air
  20. #20
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    it probably just needs a regas if they put the dye in last time they should find the leak easy.
  1. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  2. Wheres The Egg?
    By wildss in forum Jokes/Humour
    Last Post: 15-04-2006, 06:07 PM
  3. Wheres my coolant going?
    By B3NKobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 12:52 PM
  4. wheres the sound???
    By bitch in forum Car Audio
    Last Post: 06-10-2005, 09:24 PM
