Results 1 to 7 of 7
Thread: VN smells of petrol on start up
    Commodore VN 3.8 / VP 3.8
    Apr 2006
    Auckland West
    Default VN smells of petrol on start up
    O.k my vn takes about 3-5 sec to start, the CAS is new! When the car does start it smells of petrol and idle rough for about 15 sec, then comes right - any ideas?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i suspect your fuel tank breather hoses are perished. i think there have been a couple of threads about it.
    *edit*
    this thread should help you
    *sniff*
    VT
    Apr 2005
    QLD
    Checked your charcoal canister? I think they operate on vacuum with the VN's, maybe there is an issue there.
    Apr 2006
    Auckland West
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    on the vp it's towards the front of the engine bay on the drivers side, it's a round black cannister.
    check the connections to this (there should be hoses to the top) and follow these back as far as you can.
    i recall the gregory's mentioning that if you take it off and shake it, it shouldn't rattle.
    any more than that i couldn't say
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    well the reason it would smell like petrol is because it takes 3-5 sec to start, so your injectors are flowing in order to start the car, but it wont kick over and there's some excess fuel there which you would be smelling.
    as for why its taking that long to start, what does it do, just keep cranking and after a while kick over?
    could be as simple as a battery needing replacement.
    Apr 2006
    Auckland West
    Yesterday I removed the hose from the little black canister that runs to the top of the motor and it started sweet and run smooth, it doesn't smell of petrol. So today after work I will replace the canister and hopefully thats where the problem is, otherwise I'm guessing it will be somewhere else in the line, as for the battery It's all good! last night I took my car for a run (50km) withour the little hose attached and it run sweet infact it had the power that I noticed was missing over the last two months 0-100 6.3 sec, not bad for a 89
  1. Smells of Petrol
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2006, 01:55 PM
  2. Smells Like ...?
    By HER82 in forum The Pub
    Last Post: 07-11-2006, 09:34 PM
  3. air con smells like petrol
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 06:21 AM
  4. smells like S*#T
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2006, 01:21 PM
  5. My VN oil smells burnt????
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2005, 11:45 PM
