im going to put the bellmouth back into my car soon to stop the rough idle. ive heard people have modified their bellmouths by cutting them to a certain shape to improve the airflow but keep a good idle. does anyone have details of this, or a diagram?
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Even with the bellmouth it wont be smooth. VN's do not know the meaning of smooth. Effort for no real return in my opinion.
mines smooth as!!!!!!!!, get the valve train right and shell idle like shes ment to, well on a cold start she rumbles
Sorry to revive an old thread, but i just took mine out, same results as paradox had, my VP is now idling and driving like a dream, it's very very smooth indeed. It idled alot more rough with it in.
Originally Posted by wikky
also took the bellmouth out of my dads VR and is alot more responsive he loves it lol only took half an hour.
~ VN POWER ~ Click the scales
I think it's one of things that will either have a negative effect, or a positive. I haven't seen any neutral effects for anyone yet. It's either caused rough idle and a few problems, or it's smoothed things right out.
I have a feeling it has better effects on VN series 2 engines and onwards.....
Ahhh i see, maybe i got confused there. The bellmouth was to correct a rough idle problem FROM the VN S1 engine????
But that's one thing that's got me confused, if the bellmouth was put onto series 2 VN engines and onwards to VR, why is it my engine idles alot smoother now i have removed it?
Ahhh i see, no power difference thats for sure, bit it just seems to idle a bit smoother. But definantly no power difference.
The cam is the performance difference (better mid range)on s1 vns dont blame the bellmouth
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
So can 2 cylinders that are slightly leaned out from the bellmouth removal, be somewhat of a bad thing in the long run?
Well hopefully it works nicely a the set of rockers i'm putting in soon.
So i'm guessing that if you have a FI set up on a buick 6, and 2 of your cylinders are running slightly leaner, all the air pressure from the blower would be working 4 cylinders alot harder than the other 2 leaner cylinders, therefore causing a few (or one big) problem, whereas on a car like mine with only basic power mods done, it wouldn't be enough to do any damage..........???
not really. when youre forcing the air in there, and have pressure in the manifold, the cylinders shouldnt lean out really. its only running N/A it would cause a problem
I have removed the Bellmouth from mine, dont see the point in puttin it back...
Gone Fishing...
Mine seems to be running a tiny bit more rich without it. Nothing major though.
