Results 1 to 11 of 11
Thread: Help stocky fix his car
    Jun 2005
    Default Help stocky fix his car
    ok well lately my car has been having a few problems. Its getting horrible economy at 19L/100km, its been stalling at the lights after pulling to a stop, and the vehicle speed sensor is doing nothing. It used to idle roughly but thats been fixed i think by putting the bellmouth back in.
    Anyyways, here are the details
    Error Codes -
    13 - Oxygen Sensor
    24 - Vehicle Speed Sensor
    22 - TPS too low (was getting a reading of -9.9)
    Ive taken three tests using winaldl. 1st was just stationary with the engine off, 2nd was engine on and stationary, and 3rd one was me driving around the block.
    If anyone can understand these and can spot any problems let me know.
    Any other suggestions for my other problems would also be great.
    With the 3rd one, be aware that although the speed sensor says im doing 0, i was driving, that sensor is just sending no data.
    Attached Files Attached Files
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Try resetting your idle control valve..
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Jun 2005
    already done.
    also, does anyone know what wire for the ECU the vehicle speed sensor is?
    Aug 2004
    think i saw ur car the other day...cant remba where.... where do you live/dirve to for work
    VP Exec,Gsx-R 750
    Mar 2005
    Have you tried new sensors? There must be some specs for the sensors so you can measure the resistance across them?
    Jun 2005
    Quote Originally Posted by cracker View Post
    i live in wantirna
    Quote Originally Posted by Hillerus View Post
    nah not yet. pretty sure i know how to fix the TPS issue. oxygen sensor is unknown. might have something to do with the extractors installed last week. vehicle speed sensor is gonna be a tough one cause i gotta find the wires for it
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the speed sensor will fix a lot of your problems, theres some wiring diagrams on my website www.memcals.com
    Jun 2005
    is there a wire for the speed sensor that runs from the dash instruments to the ECU? what wire on the ECU is the speed sensor?
    im just wondering if there is a bad connection because my dash speedo works but the ECU still thinks im doing 0kph.
    I also tried fixing my TPS today. got it all back together in the right place but now the electronic dash on winaldl gives a reading of -13.3, but the datalog shows it at a constant 0. Any ideas?
    Doctor Bob's Avatar
    May 2004
    try measuring it with a multimeter to see if the correct signal is getting to the ecm,
    nsladden's Avatar
    nsladden is offline GET UTED
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Sep 2005
    Murwillumbah
    Jun 2005
    i think ive worked out the problem. TPS is useless cause it got carby cleaner in it. speed sensor works with level 1 dash in, but not when the level 3 is in. gonna have to switch some parts over.
  1. My stocky VP
    By jolly_97 in forum VN - VP - VG - VQ
    Last Post: 22-04-2008, 07:50 AM
  2. Stocky Rims..
    By jack.mc in forum Parts And Other Items For Sale
    Last Post: 25-04-2007, 07:18 PM
  3. stocky 83 vh (newbie
    By vh_commydore in forum VB - VC - VH - VK
    Last Post: 19-10-2006, 10:35 PM
