Results 1 to 4 of 4
Thread: fuel pump?
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Default fuel pump?
    is the vn ss fuel pump meant to be the in tank type because mine isnt in the tank? mine also never stops pumpling(motor not running but car in on position) not sure if it never reaches pressure or if there meant to be like that. thanks.
    13.3 1/4 exhaust only untuned!
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the V8 models run 2 fuel pumps, one in the tank and then a booster style pump just hanging in front of the tank. normally ifyou turn the key to on but don't start the engine you should hear the fuel pump pressurise and then stop
    Body by Holden, Soul by Brock
    the Legend will live forever
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    mine dosent stop maybe its not pressurising for some reason. under the bonnet there is a hissing noise is it possible that it is pumping air out some where and thats why it dosent pressure up? it still runs but i havnt ran it for long and only at idol so it probably hasnt used up much fuel. also there is one of my pipes from the fuel tank diliberatly cloged up for some reason not sure if that is how its meant to be but i dont think its meant to be like that because its cloged with a bolt.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    just wondering is the fuel line that comes from the fuel pump meant to go to the left hand fuel rail (mine does) and the return line to the right hand fuel rail (as mine dose also)???
    also what makes the fuel pump stop when it has reached pressure? is it something built into the fuel pump or something else??
  1. fuel pump?
    By bendez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2007, 09:35 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. VN Fuel Pump ?
    By snowcatz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 10:07 AM
  4. VN Fuel Pump ?
    Last Post: 08-02-2006, 09:58 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
