Originally Posted by
holden007
I got quoted around the $3000 mark, thats getting everything done professionally. I reckon if done properly from the start you should'nt have any problems later on.
is that using all the stuff that they put in the holden manual ss or a custom setup? because if they do it the same as holden with same parts etc there is not really a less profesional way to do it it all bolts straight up and should be doable for 1500(doing yourself) ish sometimes 1000.
13.3 1/4 exhaust only untuned!
