i just out a vr motor into my vp. i was told and thought eveything would be fine. had a flat battery so when put the jumper leads on smoke started coming out of the excelorator cable near the throtle bodies. engine lights and interior lights come on when key is not even in the ignition. just wondering if any body might no whats going on.
u use the proper jumper cables that have the surge protector on them...
are u using the vr computer? if not u need to be
- OWA650 -
"Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
Would say you have cooked some bits. Not good mate.
and 3 Dangerous non ABS VN's
I would say that the earth strap between the engine and body is not connected so the only earth was through the throttle cable which will not handle the amps required to turn the starter motor. The throttle cable might have melted through a wiring loom somewhere so it is shorting out.
