Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Loud ******* Rattle!!
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    Default Loud ******* Rattle!!
    hey guy.. the problems with the vn never stop.. i have a loud ass rattle coming from under the bonnet, the best way to describe it is i reeli reeli sloppy piston sound or a wobbly pully soundit gets worse when the engines hotter, and usually kicks in at running temp.. now ive been told its the same sound you get from a broken harmonic balancer, but whats baffleing is that the balencer is completely undamaged, no cracks nothing.. i was wondering if anyone has some places to look for the problem?? its hard to define exactly where the sound is coming from without getting ur ear torn off in the acc belt. ive replace the tensioner bracket and pully sofar
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    There are many places it could be coming from. Get under the bonnet one day and give everything a little wobble to see if anything is loose that shouldn't be. It may be a snapped bracket, or more simply somethings not as tight as it should be.
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    When my Harmonic Balancer was buggered it still looked perfect and you couldn't feel any movement even with the auxilliary belt off. It made a really loud rattling noise that started off intermittent but got worse very quickly.
    I took it to a mechanic who had a listen with a stethoscope thing and told me pretty much straight away that it was the Harmonic Balancer.
    VN V6 Commodore Executive....and a London bus
    Dec 2005
    Could it be rattly hydralic lifters? I have that problem, when the oil heats up, it becomes thinner and then theres less of a "buffer" of oil between the lifter and the cam.
    Ah, nothing like a Datsun 120 WHY!
    bendez is offline Bendez
    VP 93 S2
    May 2006
    Ballarat
    dont count out a broken torque converter bolt. i had a really bad rattling sound that seemed to be coming from the right side of the engine, then a few weeks ago the engine seized. asked around and was told it was a bottom end bearing. bought another engine, when taking the tranny off there was only one bolt left two had snapped of the fly wheel and put it out of whack this seized the engine.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Bonnet latch....
    and 3 Dangerous non ABS VN's
    Keesh's Avatar
    Jan 2006
    yer ive heard many different things, i was told it was the harmonic balancer, the tensioner pulley, the water pump, too much play in the steering pump, bottom end bearing etc etc.. ive heard em all! ive had a listen with that stethoscope thingy and noone, without pulling the engine to bits can tell me what it is.. but yer if the balancer can still make noise even if in one piece then i should replace that.. even at my proce there not cheap.. it does souund very pulley related, and is getting worse gradually.. ill try running it without the belt and see whats up then.. cheers guys
    Keesh's Avatar
    Jan 2006
    Quote Originally Posted by 88GreenVN View Post
    Bonnet latch....
    nah man its noticeably louder than something like that.. ive tryed recording it but no luck ill see if i can get a video!
    88GreenVN's Avatar
    Jun 2006
    Timming chain slapping around? Is it a metalicy spound changed by revs?
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    Yeah the old timing chains make a heap of noise enough to trigger the knock sensor and retard the timing my mates vn timing chain sounds horrible can hear it from a fair way away everybody looks when you drive up town like the motors gonna fall out on the street in front of them.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Stick your head under the car when it's rattling, and try to see how far back the sound is coming from. If it's coming from a little further back, it could be a loose/cracked drive plate - they get frequently diagnosed as ****ed harmonic balancers or big end bearings, and sound similar.
    The 1972 HQ Kingswood
    VN Calais no more
    Sep 2006
    Quote Originally Posted by Morton View Post
    Sounds good to me.
    I have the same rattle noise, starts around 1800-2000rpm and goes to about 2300rpm.
    Sounds like the chain, but I replaced that, and it isnt.
    I replaced water pump, tensioner pulley, CAS... no fix.
    It sounds like its coming from further back in the engine, im suspecting torque converter, or now driveplate... both of which i dont want to change.
    One thing that throws me off the is that whenever the harmonic balancer is removed and reinstalled (chain replaced, CAS replaced) the sound reduces or almost disappears for a couple of hours then returns.
    Dont like my driving? Get off the sidewalk!
    1988 VN Calais: CAI, 2.5inch Catback, 18x8.5shadow chrome wheels, JVC DVD player + 7inch Screen.
    Keesh's Avatar
    Jan 2006
    um yer mine does sound like its coming from the front.. can i just say that ive been listening to the engine for about a month now!! its not like i havnt been tryna listen from all directions, under ontop left right.. if i had say it was coming from anywhere id say waterpump area/ behind the water pump area
  15. #15
    Keesh's Avatar
    Jan 2006
    but i dont wanna pay a shitload to get everything along the drive belt replaced to find out its internal or something, otherwise id pay someone to drop a 5L in it
  16. #16
    Aug 2006
    If its behind the waterpump id say timing chain and/or tensioner have you changed the oil and filter lately.Also about the timing chains you can buy this chain from an engineers shop but its not the same looks the same is the same but wears very quick and has a tendency to snap.Wonder if different suppliers supply different grades of chain to auto shops.
  17. #17
    Morton's Avatar
    May 2006
    If it's been pretty consistent for a month now without getting louder, It's probably not the drive plate - or it would have smashed by now ^^
  18. #18
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by spanners View Post
    Your on the money here!!! Timming chain and the tensioner.
  19. #19
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i'd also go with the timing chain on this one. they can sound like a death rattle. does it run a little rough, irratic maybe, more vibrations?
    Body by Holden, Soul by Brock
    the Legend will live forever
  20. #20
    Keesh's Avatar
    Jan 2006
    well im in spares so if thats the case genuine all the way.. half the time u cant get genuine for vn's.. mihgt hav to go acDelco
  21. #21
    Keesh's Avatar
    Jan 2006
    i have a video in Mp4.. anyone no where i can load it up besides photobucket
  22. #22
    Keesh's Avatar
    Jan 2006
    and i just noticed that was my 399th post.. so here 400 woo hahaha.. sorri guys
  23. #23
    Morton's Avatar
    May 2006
    lol, top effort
  24. #24
    VN Calais no more
    Sep 2006
    Quote Originally Posted by Keesh View Post
    i got the crow performance timing chain and gears kit.
    Was about $130 bucks or thereabouts.
  25. #25
    Keesh's Avatar
    Jan 2006
    thats alright! i always wanted a crow cams sticker on my petrol tank!
  1. vx ss LOUD
    By aygee in forum LSx Development and Modification
    Last Post: 07-01-2008, 05:11 PM
  2. car making loud rattle
    By azza1304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 02:16 PM
  3. loud snoring
    By leon archer in forum Jokes/Humour
    Last Post: 13-04-2007, 08:17 PM
  4. loud rattle now car wont start
    By executor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 06:24 AM
  5. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
