Results 1 to 7 of 7
Thread: back wheels moved over to the left??
    VP V6 BT1,VR 5.0l statesman
    Nov 2004
    sydney
    Default back wheels moved over to the left??
    my nephew has a VP non irs and he put it up a gutter last night he says the car is still driving ok but when you stand at the back of it the rear wheels aren't sitting in the centre anymore they stick out to the left of his car???? does anyone have any ideas what he might have damaged???
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Nov 2004
    sydney
    if thats what it is how much is he looking at to get it fixed??? and can it be done at home???
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    the panhard rod is most likely bent, which he could pick one up from the wreckers for cheap and stick some new bushes in, should cost maybe $50 all up if hes got a spanner, jack and axle stands.
    but there could be more problems, like bent mounts, etc. couple of people have done the same thing over the past couple months and bent lots, which would cost a lot to get repaired.
    bendez is offline Bendez
    VP 93 S2
    May 2006
    Ballarat
    yeah it will just be a bent panhard rod. u can pick em up for like 20 from the wreckers. if ur lucky u might get onw with good bushes if not use ur old ones or by a new set.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    lash out the 8 bucks and get new bushes... seriously...
    You want to hope its just the panahrd rod, try that, if its not, take it to a suspension place and get a check done.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Aug 2004
    might be the mount... mate busted his havent hit any gutters lately
  1. Dipstick moved?
    By twb1979 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-09-2007, 04:04 AM
