Results 1 to 8 of 8
Thread: VN To VP DFI MODULE
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Exclamation VN To VP DFI MODULE
    Hey guys.
    I have had a few problems with my car but i have worked most of them out with ur help as well but now i have one more problem.
    I brought a brand new DFI MODULe for my VN and i took of my old one and i relised it has had a VP DFI module upgrade. Now is that a good or bad thing. But i replaced it with a second hand one and it worked great ie the car started straight away and wouldnt rev up or down.
    But after i had lunch about 2 hours later it went back to tis normal self. Wont start straight away and revving up and down. Wat else could it be. i will be testing the Coilk packs 2morro.
    It becomes really embarrising when ur car doesnt start straight away.
    PLZ HELP
    Thanks guys
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Check the crank angle sensor.
    and 3 Dangerous non ABS VN's
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    oh yeah i forgot! i have replaced the Crank angle Sensor. that and the computer were the 2 first things.
    88GreenVN's Avatar
    Jun 2006
    Cleaned the throttle body sensor? ....um the thing under the t/b.
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    yeah that was the first i did before i replaced the throttle body. I cleaned it made sure their was no gunk. I was looking at a few posts and some one mentioned the fuel filter. I will be testing the Coil pack 2morro hopefully.
    88GreenVN's Avatar
    Jun 2006
    Go over the connectors/earths if its heat related eg when warms up..
    vq statsman..5lt
    Dec 2006
    nsw
    2001_VXSS's Avatar
    2001_VXSS is offline keepin' it real
    VR Berlina Series II
    Sep 2008
    i have the same problem. and it only does it when it get warm. you can drive it like normal and will be fine but as soon as you drive it with some stick it will stop and run rough.. does that mean it could be a particular part?
    My Write-Off
    http://forums.justcommodores.com.au/...t-berlina.html
    Originally Posted by hotred View Post
    Will, obviously our checkers game was disrupting the public lol.
    Posted by DVSV8
    we were playing hoon checkers! did you here all V8's screaming every move!
  1. Yes, It was the ABS Module
    By RichardACampbell in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2012, 09:28 AM
  2. ABS module
    By gopher in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2008, 08:27 PM
  3. dfi module
    By shumway in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2008, 10:53 PM
  4. air bag module
    Last Post: 11-12-2005, 08:19 PM
  5. Dfi Module
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 05:14 PM
