Results 1 to 16 of 16
Thread: Is this VP fault, V6 fault or just bad luck?
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    Default Is this VP fault, V6 fault or just bad luck?
    My passenger side exhaust manifold has a crack between the middle and rear runners. When I removed the manifold from my spare VP I noticed it was cracked in the same place (though this was a smaller crack, on my car it was almost the whole way around). I am wondering if this is a known V6, or even VP problem?
    Does a crack in the exhaust manifold above the O2 sensor mean the computer thinks the engine is running lean and compensate by making it run rich?
    VN S2 Berlina Wagon
    Apr 2004
    This is very common with VN S2 and VP's. It's because there made out of cast iron. My passenger one had a very fine crack on my VN s2 and only discovered it when i upgraded to extractors. If you have the cash then its a good excuse to get extractors
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    mine is cracked in exactly the same place right round gonna weld it up with a strata rod and the ark welder tomorrow.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Yep got one to weld up too. Drivers side. Just have to take it off first...
    and 3 Dangerous non ABS VN's
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yep, and they said one of the reasons they replaced the series one steel headers with the cast ones, was cracking, yet ive never seen a cracked one, but we have 2 cracked s2 ones and one welded one in the shed.
    Aug 2006
    make sure you preheat and postheat with gas tourch and that you clean out the crack well otherwise you should have no problems there is also a gas rod I cant quite remember the code something like a bc15 technical rod should be able to get one from the local engineers but they about 15 bucks each and may also have to get the gasket surface planed or it might just twist and crack again.Done a few before with no problems without planing them
    88GreenVN's Avatar
    Jun 2006
    Ooops mine is the steel type header......
    88GreenVN's Avatar
    Jun 2006
    But I had the cast VS one welded 3 years ago before the car got sold off.
    Aug 2006
    88GreenVN's Avatar
    Jun 2006
    Mig it is. Innershield wire (flux core stuff) works a treat.
    Aug 2006
    Its good in the wind that flux core wire but can be messy i find.I got a big bottle of gas and a huge welder that you cant change the polarity of the cables so cant use the gasless wire anyway.But man can it weld panel steel and anything up to about 3/4 inch.
    Oct 2006
    Kingston
    I'm glad to see this is common, and not just me!
    Quote Originally Posted by MyVPIsFasterThanYourVP View Post
    LOL he has a point, anyone know the answer?
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Be glad it's the passanger side manifold, it's so much easier to get to than the drivers side.
    Aug 2004
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by spanners View Post
    A lot of it is to do with the quality of the wire.... NR2107 spatter all over the place. NR211 Smicko. Weld 10" concrete lined pipe but weld clean as in 30 minis flat. 3 runs root/filler/cap. Put 10 lenghts (9m) in one day.
  16. #16
    Aug 2006
    Is there much difference in price between the two,costs me $80 a 25 kilo roll of mildsteel gas wire over here lasts for ages my mate fills my bottle saves me heaps thats for sure.
  1. A fault already??
    By KITTAU in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-05-2007, 03:45 PM
  2. vr bcm fault?
    By markovr in forum Electrical Wiring / Questions
    Last Post: 23-07-2006, 05:50 PM
  3. fault 26 and 46
    By jessedevery in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 11:29 AM
  4. srs fault
    By btsmash in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-02-2006, 08:20 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
