is there suppose to be an oil pump inside the timing cover of a VP holden?
WHere is the pil pump in a VP commodorE?
**oil**oil**
6 or 8?
Looking at the manual for a V6, I would say yes, you can access part of the oil pump. Can get picture if required.
Illegitimi Non Carborundum
yes its a 6 my car has no oil flow what so ever im scared to drive it cause it may seize plenty of oil in it i might check the oil pump can it be removed and replaced via the timing cover?
the oil pump drive gear and shaft runs of the crank or the cam behind the timing cover. if its got no oil press/flow id check the filter, they some times block up.
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
brand new filter on it hmmmm
hmmmmm sounds like the pump isnt pumping ot the oil pick up in the sump is blocked
that means engine out sump off ect ect
when you take the filler cap off can you see black chunky stuff covering the rockers???
MY RIDES
[SIGPIC][/SIGPIC]
havnt looked i recently changed the timing cover it seemed to come with an oil pump already on it maybe its not all there. i thoguht the oil pump was that thing attached to the timing cover and the oil filter with the gears that go around the crank shaft to turn it.... lots of people are telling me other things... i ganna take the timing cover off again and have a better look
How long can i idle the car before damage can be caused as a result of no oil flow?
wait... if i took the oil filter off and started the car.... would that tell me if the pump is working?
hmmm **** sake im ganna do all shit shit and hwen i get it going its ganna seize on me ffs
ur better off pullin it apart then just tryin 1 thing at a time and running it up ur ganna **** the motor
MY CAR
It wasnt a supercheap filter was it theres been a few cases over here of the supercheap filters falling apart inside and blocking flow round the engine making the oil pressure light come on and stuff.just a thought.
nah it was a good quality one... how long can it take for oil to start flowing?
u probably got airlock
MY CAR
whats airlock
u got no oil in ur pump just full of air like a water pump when it fills up with air
MY CAR
how do i fix it?
well i dont know much bout the pumps on them but u can probably pull the pump out to tell if it has oil in it if not u could prime by fillin the pump with oil.im not to sure bout it but id say its a possibility just ask round see wat others think
MY CAR
oil pump is part of the timing cover check out below can scan the next page to if you want
the manual says to fill the pump with petroleum jelly so it primes faster or it could take a while 10 20 seconds plus it has to fill the filter fill the filter and oil pickup
well im off to bed catchyas good luck with it dont **** ur engine
MY CAR
Try filling the filter with oil and putting it back on. Can get a bit messy but may fix the prob if you didnt do that.
One point when I changed the oil in the 5.0L the car had a bad knock on start up afterwards - sounded like it had done a bearing in - not happy. But was saved by some engine flush as the oil pick up was blocked. 30 mins later engine flushed and had fresh oil/filter and the knock at start up was gone.
and 3 Dangerous non ABS VN's
engine flushes are dodgy i dont trust them
MY CAR
