Results 1 to 25 of 25
Thread: Rust around the Back Window
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Rust around the Back Window
    The sedan has developed rust around the window and I only thought it was in 2 small spots but on closer inspection it is starting to discolour all the way around. ****** ALL FIXED NOW *******
    So its window out and some repair work over xmas before it gets too bad.
    Does any have a method or sealing the rear window so it wont happen again?
    have included a pic of the close encounter with a gutter before I purchased the car
    The two rust spots were what you could see before the window came out.
    and 3 Dangerous non ABS VN's
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    it may be even worse once you get the windscreen out....i had rust like that in my old vn calais and at first look it wast too bad, but once the windscreen was out the rust went into the underside of the rood about 5cm and all the way down one of the side pillors.
    as for how to seal the window once repaired, just what they always use, sikaflex/urethane.
    88GreenVN's Avatar
    Jun 2006
    Bugga, not going to like what I see then am I. Oh well. Just another job to explain to the wife. Something like it's not so bad dear.... could have been an engine.
    wagon
    Nov 2006
    South East Vic
    yeh mate theres not too much you can do, i work at a panel shop and our standard procedure for that si to wire wheel the rust out, then metal condition it, then use a rust proofing etch prima and then normal prima then your topcoats, if you manage to seal it up properly with that procedure you shouldnt have too many worries with it again, sixalex and urathane is only used to seal the window in, not really used to stop eventual rusting
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Vk4lyk View Post
    Thank for that, I was hoping not to have to do a respray by doing it now but maby not. Still I'll do the repair and see how it looks when thats done before worrying about paint. I just hope the rust is not to bad under the rubber.
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    As i have the same prob! vk4lyk approx how much does the shop you work at charge people for the job?
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    88GreenVN's Avatar
    Jun 2006
    I'll get the windscreen people around after xmas to remove glass. Then have a go at the repairs myself......
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by MyVPIsFasterThanYourVP View Post
    i would like to know how this goes......
    Window comes out Monday. I'll do some photo's of the work
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    niceeeeeeee i have the same problem only ALOT worse..... DAMN IT! y did my car have to have cancer? haha o well it should be cured soon HOPEFULLY!
    88GreenVN's Avatar
    Jun 2006
    Windows out and wire brushed. Coated with rust kill. Undercoat and paint next few days.
    88GreenVN's Avatar
    Jun 2006
    Pics of the rust kill on the car plus the wire wheel use to remove all the paint and scale. I also touched the rust spots with a grinder (4") very light.
    I used a small brush to paint the rust kill on and will leave to dry over night.
    Bent_6 is offline 3/4motorsport
    VT S1 Acclaim V6/ VS SII Acclaim V6
    Jan 2007
    Just right of the redline
    Quote Originally Posted by padrickz88 View Post
    Yeah im hearin ya mate, every Pre VP owners nightmare is rust around the back window.
    A good mate worked on the VQ line and said they only dipped them in rust proof to the top of the boot lip so it missed the back window sill.
    Then with VP the whole car was coated.
    Does this sound familliar to anyone who may have worked at Elizabeth then?
    Steve
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Bent_6 View Post
    Steve
    I didnt work at Holdens but thats probable what happened.
  15. #15
    88GreenVN's Avatar
    Jun 2006
    When the window came out the rust didnt look too bad at first but once cleaned I had about 40 spots of rust. The window was not stuck down in 2 places (fitted poorly). I cut the sticky glue/rubber off with very sharp knife and paint scraper.
    I used a small drill with the wire brush thingy and lightly went around and removed all the black paint first and then the car colour. This showed up many more small bits of rust!! Then I got the 4" grinder and lightly took the top of all the rusty bits. So most of the top window chanel, 70% of the right upright and 50% of the bottom chanel. 2 spots on the left upright.
    Cleaned all the dust and metal of with a rag - be careful of the grinding dust scratching the paint.
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Undercoat and brushed on paint.
    A proper paint job to be done later.
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Finished the paint with black strip.
    Window goes back in tomorrow.
  18. #18
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    niceeeeeee, how much has this costed u all up so far? just so i know how much to roughly spend?...... and did you have 2 replace the rubber? or was it in good enough condition to re use?
  19. #19
    88GreenVN's Avatar
    Jun 2006
    Cost so far Window removal and replace $150.00 (est) Includes rubber
    1 sheet of 320 dry rub $1.10
    Rust kill $10.00
    100mil tuch up paint $10.00 (metalic)
    Undercoat (had some in the shed) but 1 or 2 spray cans $15.00
    Roll masking tape $3.50
    1/2" paint brush $3.50
    Tin thinners (had some) but small can $9.50 ish
    Hope this helps
  20. #20
    88GreenVN's Avatar
    Jun 2006
    Getting the window in today so a finished pic later if the rain holds off!!
  21. #21
    88GreenVN's Avatar
    Jun 2006
    All done. Only cost $130 for the window out/in.
  22. #22
    88GreenVN's Avatar
    Jun 2006
    I'll get a final pic when the rain stops
  23. #23
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
  24. #24
    88GreenVN's Avatar
    Jun 2006
    nicccccce.... so probably would of done this for about 180-190?
    Yep about that much. Looks a bit dodgy still on the top of the roof - but rust is stopped now and I can rub the roof down later for a respray when I get the $$$.
    You just cant leave it with undercoat on it so I slopped the colour on nice and thick It can rain for a week now
  25. #25
    88GreenVN's Avatar
    Jun 2006
    I can report after all the rain we had today - no leaks with the rear window. Very happy.
    Flat battery on the camera so photo of the finished job tomorrow.
  1. rust around the windscreen and back window
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2006, 09:15 PM
  2. Window Rust
    By vlmitch in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-04-2006, 05:32 PM
  3. back window
    By SUSPECT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2006, 05:41 PM
  4. My back window leaks
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2005, 05:26 PM
  5. Window won't go back up!!! (VP Berlina)
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 08:22 PM
