Results 1 to 10 of 10
Thread: 5 Speed Manual gear oil change
    1992 VP Executive
    Dec 2006
    Default 5 Speed Manual gear oil change
    When and how should I change the gear oil on my 5 speed 92 VP?
    Also when I change from first to second there seems to be a little more noise (rough sound from the gearbox)compared to when I change to other gears, second to third for example. Any comments?
    5 speed v6 vn commodore
    Dec 2006
    waroona WA
    probably change oil every 40 to 50,000 also ur gearbox probably just old and starting to wear
    MY CAR
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    2 hex drive plugs (use allen key to get them out) on driver side of box lower one drains the dexron 3 oil out and upper one is the filler you fill it until the level is high enough so the oil comes out of hole.You need some sort of pump or oil syringe to get it in and its a bit tight for room if you are doing it on the ground.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    vn calais
    Dec 2006
    Another way i found to fill it up if you dont have a pump (not sure if this is 100% ok, but i done it and no probs) is remove the shifter unit from the center console and fill it up slowly from there. Seemed to be easier and worked fine. You may have to drill out the metal plate thats pop rivited to the floor to get to the 2 bolts at the rear, and just rivit them back in. Its pretty simple.
    Oct 2006
    Since most oil bottles have spouts its not a problem to get the oil in. I used shell 75-90 synthetic oil in mine an it made the shift heaps better. Holden says to use ATF but both 5 speeds ive got had normal gear oil in them.
    1992 VP Executive
    Dec 2006
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    How Much Oil do we need for a Oil change on 5spd VN
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
    vn calais
    Dec 2006
    Quote Originally Posted by m3taL View Post
    its about 2ltrs on the v6, not sure bout the v8
    m3taL's Avatar
    Aug 2006
    Bendigo, Vic
    i got 2 lt of a 80w/75 nice thick stuff as she is makin some un-usual noises and 1/2 shift is a bit funny.
    My Ride
    Family Ride:
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i had trouble getting into 2nd for a long time when i first got my VN. it had transmission oil in it, i put ATF in it and then changed it again after a few weeks to really clean it out. it's been good now fora few years
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Revs not Dropping On Gear Change - VY S Manual
    By VY5Speed in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-05-2007, 07:31 PM
  2. diff gear change
    By V6VL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2006, 06:46 PM
  3. Rough gear change
    By veclubby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 10:15 AM
  4. 5 speed Manual gear knobs
    By vkberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2005, 08:10 PM
