Results 1 to 12 of 12
Thread: Need help with intercooler piping!
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Need help with intercooler piping!
    hey guys, intercooler piping is done all except where it connects to the throttle body its a tight 90deg bend, i was gonna use a 3" 90deg steel bend but its too big, even when cut down, and the silicon bends are like $100?!!!
    my setup is pretty much identical to RAREVP (i didnt really copy you but it was just the easiest way to do it!!!
    Note: turbo isnt bolted in, its sitting there so it will sit higher, just waiting for more welding (wanted it postioned
    and ill have a heat shield between air intake and airpipe
    heres some pictures
    last picture is RAREVP's setup, i managed to grab a look at it last VSS cruize
    92 VP Calais International - RIP VR Turbo
    Jul 2005
    Echuca
    maybe just get a bit of pipe with a nice mandrel bend in it and weld it to your other piece of pipe with a silicone reducer connecting it to the tb?
    are you using 3" piping? what size is the throttle body? 2.5"?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nahh throttle body is sneaky, its like just over 3" which means i cant get silicon on it GRRR!!! my intercooler piping is 2.25" from the turbo (2" outlet) then hits the cooler and jumps to 3" (for air velocity to fill up the cooler.... thanks luke :P)
    then 3" to the throttle body and 3" exhust from the turbo back
    VN Commodore
    Feb 2006
    i got a piece of 3 inch silicone hose on my thottle body. put it in hot water. before you do that, shave the inside off on at angle.. not too much. i didn't even cut through the first layer.. then when it is nice and warm it should slip on.. it will take a little bit of anger to get it on though.. i cna't remember who it was, but they said when ya get it on there don't EVER take it off.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by defa View Post
    hehehehehehe cheeers man,
    i tried shaving a angle, but i didnt try hot water, im out of silicon anyway need to go down the shops and get me some more... gonna get longer coil pack leads aswell
    my manifolds are %100 ready to weld... just waiting.....
    VC Twin Turbo, VN Turbo, VY Storm
    Oct 2006
    a 3 inch 90 degree bend will work fine just make sure you dont need to take it off.
    Have you got the intercooler mounted?
    also dont have so many silicone joins every time you boost it one will blow.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Furious_8 View Post
    already 1 step ahead, what you do is tack the piping, in 4 points
    then force the silicon over it then put the clamp on so the clamp cant go past the welds = no more blow offs!!!
    3" 90 degree bend, what kind of material ?? steel or silicon???
    Oct 2006
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    because im not %100 on the angles and stuff, silicon is the easiest way because then i can ajust it later, and its more welding that isnt nessecary,
    yeah got a 90deg silicon bend priced up... $60 soo that should work
    moved the coil packs today (grounded aswell)
    with longer spark leads.. its all time...
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    AWESOME!!!! Para makes me wuna turbo my Dorey, looks like a sexy setup to me mate. Hope it lasts for a while, will be sorry to hear is she gives u shit after its done.
    VN Calais no more
    Sep 2006
    Why not just weld the thing?
    silicone bend like in rare vp photo
    Engines move.
    Intercoolers mounted to the chassis dont.
    Without silicone or rubber bends, you will find yourself continually fixing cracked pipes and welds.
    Kind've the same as if you have an exhaust without a flex pipe.
    Dont like my driving? Get off the sidewalk!
    1988 VN Calais: CAI, 2.5inch Catback, 18x8.5shadow chrome wheels, JVC DVD player + 7inch Screen.
  1. intercooler piping...
    By cruzncommo in forum V6 Development And Modification
    Last Post: 24-10-2007, 09:41 AM
  2. HSV Piping
    By bush_basha in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-08-2007, 09:47 AM
  3. sc14 intercooler piping
    By Matt_vp in forum V6 Development And Modification
    Last Post: 04-03-2007, 10:18 PM
  4. Intercooler piping
    By defa in forum General
    Last Post: 18-01-2007, 12:59 PM
  5. Intercooler piping
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2006, 10:30 PM
