Results 1 to 5 of 5
Thread: Removing Sump
    VP Commodore
    Nov 2006
    Default Removing Sump
    Has anyone here ever removed a sump off a VP commodore without a hoist? if so how do you go about it
    bendez is offline Bendez
    VP 93 S2
    May 2006
    Ballarat
    to remove the sump u dont need a hoist. just use a set ramps or axle stands. you have to remove the crossmember to get to the sump not the easiest of jobs with all the oil and shit everywhere
    VP Commodore
    Nov 2006
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    you can go buy an engine cradle, don't know what they are worth exactly but i'll be guessing aroung 200-300 bucks, it's a betal bar which sits across the front fenders and has an adjustable hanger to support the motor. then you can remove the cross member.
    But you might just be able to unbolt the motor and lift it up a bit, thats what i did, but i had a hoist and put a stand under the front of the box/bell housing and lowered the car.
    Or the another option is to lift the front onto a set of jackstands then get a jack under the front of the box/bell housing and lift the motor enough to get the sump out, a bit of a prick but you might be able to do it.
    One of my mates used a susposively 30kg rated roof hook to support one of his motors to remove it. lol, you can try to support the motor with a structure with a rope/chain or something.
    Soon to be back on the road, Turbo VG.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i did get the sump of my VN V6 without lifting the engine or dropping the subframe but i did have the box of the back at the time doinga clutch change. i undid the sump, then reached inside the sump and unbolted the oil pickup and then got the sump out. bugger of a job though to unbolt that pick-up. really need a person with small hands and a double jointed wrist. but not much use to you unless you've got the box off
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. removing sump without taking out the engine - 83 VH
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2007, 11:50 AM
  2. What is it? under the oil sump....
    By AlpineRaven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 05:30 AM
  3. Removing stuck sump plug.
    By Uber_Matt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2006, 09:14 AM
  4. removing VL 6cyl auto trans sump
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-11-2005, 10:51 PM
  5. sump
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 01:05 PM
